      04-22-2022, 02:04 PM   #1
Elar3
Drives: 2006 BMW X3 e83
06 E83 Need sizes please: exhaust manifold gaskets and hardware
I need the bolt sizes and the gasket sizes for the connection between the mid exhaust pipes to the manifold downpipes.
Please / thanks
      04-23-2022, 12:46 PM   #2
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
First of all, you can use sites like realoem.com to do all kinds of part lookups. I'm pretty sure your car is equipped with the M54 engine. You may want to clarify your make/model info since E83 is a chassis designation which covers a variety of models. E.g. 2006 X3 3.0i
Assuming I'm right,
exhaust gasket, 2x part number (PN) 18107502346
bolt is an M10x40, 2x PN 11621427586
nut is a special M10 copper nut, 2x PN 18301737774
Copper is used to prevent the nut from seizing.
Your local BMW may have it all in stock. Auto parts stores should have the gasket available and may have the hardware. If you're stuck going to the local hardware store, try and get stainless steel parts.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project
2012 Alpine White X3 xDrive35i - My new snowmobile.
2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive.
      04-23-2022, 02:40 PM   #3
Elar3
M10 seems a little thick. The engine is 3.0i
The pipes are only 2 in thick.
