08-25-2019, 06:38 PM | #1 |
Rep 3,064
DIY - WiFi Antenna for CarPlay
Hello
I finally decided to make a write up how to add WiFi antenna to G01 with NBT EVO(Professional Navigation) that doesn't come with Antenna from factory. If you don't have one of option above: 06CP Preparation Apple CarPlay 06NW Telephony with wireless charging 06WD WLAN Hotspot For 99% you are missing WiFi Antenna. CarPlay or Screen Mirroring can be added if you don't have this options and you have 0609 which is Professional Navigation and if you have problems with connection, reception etc. WiFi Antenna would help. That was my case. My G01 doesn't have any of that options, so I decided to retrofit WiFi Antenna (which is BIG to say it's retrofit, since it takes 10-15 minutes to install it). CarPlay and Fullscreen was already activated by me so it was only matter of Antenna. I bought cheap Antenna at China - famous Ali site Just look for "FAKRA WIFI BMW". It was like 3 USD and 3 USD for shipping. If you want OEM option, you can go with it - 61119278133 part no. I used this guide to remove headunit - https://www.newtis.info/tisv2/a/en/g...nit/1VnbgcYJTA And WiFi Antenna connects to the 9 connector at the picture above. I put WiFi Antenna behind Headunit and it was perfect place for it. This one cheap on buy has long cable but it was tied so I left it as it was. Perfect and stable connection even on the back seat and outside the car Here are some pictures of installing it. Took me like 10 minutes - but i'm not doing it for the first time. You need plastic tool, and some Torx Wrench. Pretty easy and straightforward. If you guys have any questions, let me know.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
08-29-2019, 10:46 AM | #2 |
Rep 547
kubax86
A million thanks for the guide! From which side did you start unclipping the trim and then pulling it off?
Previous Bimmers: F25 X3 20d LCI xLine, F30 320d Luxury
09-05-2019, 06:22 PM | #4 | |
Rep 3,064
I started from the right side Good luck!
09-08-2019, 06:20 AM | #5 |
Rep 20
Thanks for the guide, it took me 40 minutes to remove trim, attach the antenna and re-assemle........it then took me 2 weeks to realise I hadn't plugged the cable into the right socket -
I have now and it took me 15 minutes from start to finish including re-looking at this thread |
09-08-2019, 07:44 AM | #6 | |
Rep 3,064
Recommend to anyone that have problems with CarPlay connection.
09-08-2019, 12:08 PM | #8 | |
Rep 3,064
Yes, you definitely have it. You're good to go when it comes to Carplay.
09-08-2019, 01:54 PM | #9 | |
Rep 90
Do you sell Carplay coding? 🤔 |
09-08-2019, 02:03 PM | #10 |
Rep 3,064
09-09-2019, 08:53 AM | #11 |
Rep 3,729
Thank you!
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
10-06-2019, 07:09 AM | #12 |
Rep 22
How the hell do you remove the A/C & Radio panel?
Tried everything but still it won't budge. That guide you posted said to use some sort of tool but still I can't figure out what to do. |
10-06-2019, 09:54 AM | #13 |
Rep 3,064
Use trim tool remover.
Leveredup37725.50 |
03-03-2020, 03:01 PM | #18 | |
Rep 32,881
No need to code the wifi antenna in. Carplay can’t just be coded, need to buy a solution from a 3rd party seller, possible just by USB stick but depending on your software version you might need the laptop and enet cable method. |
03-04-2020, 03:18 PM | #20 |
Straight Six Convert
444
Rep 894
Drives: 2019 X3 M40i
Here is the part number (in yellow) and photo of where it connects
2019 G01 X3 /// M40i in Carbon Black, 718M 21's, M Sport + Pack, Pano, F/Mirrors, Full Screen CarPlay Activated, ThinkWare F770 F/R DashCams, Gyeon Q2 Pure Ceramic Coated. PCW BackBox Mod
03-05-2020, 06:08 AM | #22 |
444
Rep 894
Tags |
android, antenna, carplay, diy, fullscreen, miracast, wifi |
