      04-16-2012, 08:39 PM   #1
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
ABS, BRAKE, and 4x4 light just came on 2007 X3
Like the titles says guys, I need help every thread I have read here is on 2011 models.
first 2007 X3 3.0si with 71k and no problems ever. No warranty on the car.
The wife is driving it home today from work and call me that the ABS light, BRAKE light, 4x4 light, and bulb out light came on on the truck. As i said before from the 2011 model about computer faliure, transmission module, and a number other things. I need to get to the bottom of this ASAP and get whatever it takes to repair it myself.
I am good on E30 M3's not as much as the X3, I need HELP!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      04-29-2012, 04:22 AM   #2
-Jay-
Drives: 06 X3 3.0
sounds like you're transfer case actuator is bad. i've had that problem. not a cheap fix. the dealer wants around $1400 for parts/labor. at least that's what the dealers up here in WA want.
you can buy the part on sites like ecstuning for around $700+ and just change it out yourself. it's fairly easy. or if you want to wait to spend that much money on replacing the part, there's the "free fix":
http://www.bimmerfest.com/forums/sho...d.php?t=566880
as for the bulb out light, just check all your exterior lights to make sure they're all working. mine went off a couple weeks ago. ended up being one of my taillights. i wish the dash would tell you which bulb is out like it did on my old e46's.
hope this helps.
