      03-21-2014, 06:59 PM   #1
am36
Squadron Leader
England
Drives: X3 2.0d M Sport - DSB Manual
N47 Engine - Timing Chain issues?
Hi, my Brother (who has an '09 E90 with 65k miles) just phoned me to say that his timing chain has failed.
It appears to be a well known issue on the N47 engine built between ~'07 - '09 particularly.
Suppose most of the 2.0D N47's fitted to F25's are still relatively low mileage and hence there may be limited failures to date?
Do we know if this problem is definitely designed out?
Cheers!
- F25 2.0d M Sport manual, DSB, black leather with fineline wave wood, Pan Sunroof, 368 M alloys, exterior trim and rails in matt aluminium, reversing camera, sun protection glass, windscreen with grey shade band, heated front seats, extended storage, powered tailgate, Xenon's, bluetooth c/w USB, DAB.
      03-22-2014, 06:11 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Cheers!
Can of worms. The chain failure issues should be past for current productions, as in 2011 the revised parts (yes after the initial problems were supposedly solved) are said to be sound. But there are still reports of noise in the chain mechanisms, but not read of any recent build failures.
Wise to run with the extended warranty (Drivetrain as a minimum) once out of the 3-year warranty, if you want to have peace of mind.
Then with xDrive I'd be running under a warranty anyway.
HighlandPete
