      02-26-2022, 05:43 AM   #1
killerbunnyzombie
Drives: BMW X3
Does the 2017 BMW X3 xdrive28i have the timing problems I hear about?
I have read and heard about timing problems with the N20 engines. Is that something to worry about for the 2017 X3 xdrive28i?
      02-26-2022, 09:20 AM   #2
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
I believe the issues were resolved in the 2016 model year. Someone with more knowledge of the specifics will likely chime in.
1986 Delphin 528e - Roof rack equipped lumber hauler.
2008 Platinum-Beige X3 3.0si - Current project
2012 Alpine White X3 xDrive35i - My new snowmobile.
2020 Estoril Blue 440i xDrive cabrio w/MPPSK - This car is a blast to drive.
      02-26-2022, 09:47 PM   #3
tom2021
Drives: 2017 BMW X3 xDrive28i
https://bmwtuning.co/bmw-n20-common-problems/
It seems 2017 F25 did not have the same timing chain problem.
      02-27-2022, 01:14 PM   #4
joesid
joesid's Avatar
80
Drives: 2016 BMW 340i xDrive
I'm pretty sure it's any F25 with a build date of 02/2015 or later. My mom's X3 was built 01/2015, and I'm under the impression it's got the bad tensioner. That cutoff also applies to the 10year/125k thermostat warranty.
F25_x311.50
      08-30-2023, 08:39 AM   #5
slowblackx3f25
xdriv33
slowblackx3f25's Avatar
Drives: 17' BMW x3 F25 xDrive28i xLine
2017 BMW x3  [0.00]
it depends on the build date.
2017's are OK, it's 2016 and older X3 N20 models.
BLACK 2017 BMW x3 xDrive28i [N20] xLine Package, Comfort Access, Build Date: 03/03/2017. *[THE POWER OF 33]*
      09-25-2023, 09:18 PM   #6
richardodn
Unless this has been updated, for the N20 in the F25 the affected date range is February 15, 2012 to February 28, 2015. In other words for all models, the affected date range are models with the N20/N26 through Feb 2015 production. March production and later is unaffected.
MC-10204534-9999.pdf
      09-26-2023, 08:53 AM   #7
slowblackx3f25
xdriv33
2017 BMW x3  [0.00]
Attachment 3285261
Thank you very much!!!
2017 and newer x3 N20 engines do not have timing chain or tensioner issues.
      04-20-2024, 04:45 PM   #8
chatvmax
Drives: 2016 X3 F25 N20
Attachment 3285261
I have a 2016 x3 and I do have slack when the car is cold BUT no noise,,, and no issues at 106k miles ,,
Where is my " build date " and to be sure if it's AFTER what build date am I OK ???
Thank you ))))
      04-25-2024, 08:24 PM   #9
richardodn
You can input your VIN at sites like realoem.com or mdecoder.com. If your car was manufactured in March 2015 or later, you should be free of the issue described. 2016 MY production typically starts in the fall so you should be good.
