      03-11-2013, 06:00 AM   #1
aaccon
Drives: 2023 G21 330i M Sport
Disconnect Rear Camera to repaint tailgate
Hi
My X3 rear tailgate came to grief when a garage door came down whilst it was up.
Apart from the repaint the dealer has said it will cost an additional $120.00 to re-code the computer as the rear camera has to be disconnected for the repaint, then re-connected and this will cause an error on the computer.
Is that correct ?? wouldn't the error go away when the camera is reconnected. Is it something I can resolve without another 120.00 cost..
Cheers...
      03-12-2013, 09:29 PM   #2
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
One way to find out... But that would mean a trip to the dealer if coding WAS required.
      03-13-2013, 04:24 AM   #3
clivem2
Drives: X3 M40i
So what happens when we replace the battery on an X3, does it need re-coding?
Previous: E30 318iS, E39 520i 523i 523i, E46 vert 330i 330i, E93 vert 335i, F25 30D 35D
      03-13-2013, 08:22 AM   #4
02420X3
Drives: 2011 X3 35i
There is programming required when an X3's battery is replaced. Battery replacement is not a DIY job. The X3 must be "told" about the new battery. I don't know how involved the programming is.
      03-13-2013, 01:32 PM   #5
lbjgh
lbjgh's Avatar
Yep, I wonder if a OBD2 scanner could clear the codes.
In Ontario, there are now "drive clean emission" testing using requirements using the OBD2 port. If an error exists, the car will not pass and the car cannot be plated. Supposedly, it takes two weeks of driving after a battery change before the car can pass the emission testing using the OBD2.
Below is an extract from the manual.
      03-14-2013, 04:34 AM   #6
clivem2
Drives: X3 M40i
I can't help feeling this is all getting too complex.
