      08-05-2012, 03:13 PM   #1
bluesmachine
Drives: 2023 X5 45e blue/cognac
2011 BMW X3 35i  [0.00]
1998 BMW 328ic  [0.00]
Hardwire RADAR detector install question
I'm heading to a local place to get a hardwire Passsport 8500 radar detector install.
It will be placed on windshield and the guy over the phone said they will run an unseen cord thru the headliner.
Has anyone done this ? I think I remember reading about getting power from the rear view mirror somewhere in this or a different forum.
It's a 2011 X3 35i (Alpine White on Red for the record!).
Thanks in advance.
      08-06-2012, 07:56 PM   #2
ReturnZero
Drives: 2013 X3 35i M-Sport
I did my hardwire, used power in the top console from the wiring harness headed to the mirror. Wasn't a big deal. Just make sure that you can't see the wiring and make sure it's a reputable shop that offers some sort of labor warranty.
      08-06-2012, 08:40 PM   #3
0utlier
0utlier's Avatar
Drives: X3 XDrive35i
I wouldn't pay someone to hardwire your detector. There is a super easy DIY way to hardwire from the fuse panel in the back. No cutting into your top console or anything. It's as stealth as any other way with no wires to be seen. You need a simple fuse tap, hardwire kit, and a few feet of 16 gauge wire (I think that's the gauge) to extend the hardwire kit.
Less than 30 minutes from start to finish and you're done. If you (or anyone) is interested in my install I'll document it with pics and video.
      08-06-2012, 09:59 PM   #4
cadman50
Drives: 2012 X3 35i, 2021 X3 M40i
Outlier I sent you a PM.
      08-07-2012, 06:27 PM   #5
0utlier
0utlier's Avatar
Below is a quick video of what my installation looks like. It's real simple to do. I started at the detector and started running wires. When I ran out of wire from the direct wire kit I used two butt splice connectors and added more wire as needed to reach the ground point and fuse panel.
On the fuse panel I used fuse 186. It is on the bottom row. Third from the left.
What you'll need.
You can buy this stuff where ever you want. Below is where I got mine.
Direct Wire Kit.
http://www.amazon.com/Escort-79-0010...words=fuse+tap
Fuse tap (add-a-circuit)
http://www.amazon.com/Littelfuse-FHA...words=fuse+tap
Extra wire
Several feet of black and red 16 gauge wire (I think it's 16 gauge). Just visit Radio Shack or the like and roughly match the size of power lead on the add-a-circuit.
2 butt splice connectors
You can get those at Radio Shack or any automotive parts store.
Tip...
Put the 20amp BMW OEM fuse closest to the prongs on the add-a-circuit, and put the 10amp detector fuse above it lined up with the red power wire of the add-a-circuit.
Any questions just ask.
      12-15-2012, 01:24 AM   #6
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
I wouldn't recommend using a 10 amp fuse for your detector. It's not really protecting your detector unless you have another fuse somewhere in your wire.
I'd say 2 Amp for the radar detector's slot. Actual draw from something like a radar detector is like 0.4 amps, maybe 0.8 - 1.1 amps at full volume (during an alert) and brightness.
The add-a-circuit's are rated for 10 amps.
Great tips on hiding the wire! I'll be doing this probably tomorrow. Strange that the F25's fusebox is in the boot area. I'm used to searching behind the glovebox. While I appreciate the extra room to work, so much more wire needed lol.
      12-15-2012, 09:14 AM   #7
02420X3
Drives: 2011 X3 35i
There are two fuseboxes. One is behind the glovebox, one is in the rear cargo area. You'll find the fuse diagram near the rear fusebox.
      12-15-2012, 03:37 PM   #8
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Do accessory circuits only turn off after 15 min?
I checked with a test light and it seemed to work, but then when i powered up the detector, it won't turn off with ignition.
      03-14-2013, 02:18 PM   #9
lotus18
Drives: 2013 x3
i tried your suggestion, but the186 is always hot...wonder how u made it switchable.....?
anyway, with some modification,i was able to hardwire to the overhead console with the green/brown wire going to the homelink as suggested by alanintx in other thread.
