      10-04-2020, 09:53 PM   #1
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
Need some help activating led drl.. 2017 LCI halogen retrofit to oem xenon headlights
Hey my fellow f25’r.
Has anyone retrofitted halogen to oem xenon headlights on a Lci f25 x3?
I have a 17 BMW X3 f25. It came with stock halogen headlights. I acquired a pair of oem xenon headlights and have completed the rewiring to my plug in order to work with the xenon headlights.
This is what was done.. I Added additional ground wire to pin#4 and 7. And then I tap 4&7 to #2. And then I moved pin 12 (green/blk) parking lights to #8. And moved #6 (high beam) to #9
So my local coding guy have started the recoding on my vehicle to accept the xenon headlights. We were able to get the turn signals and low beam (xenon) to work. No errror/warning code.
As for the ae drl we are having issue activating them. And for the high beam shutter I didn’t really care for it so it is not activated. ANY HELP FOR THE LED DRL!??
Here are some pics of the car, lights and rewiring.
      10-05-2020, 02:44 AM   #2
MSport_Jon
Drives: X3 F25 LCI /// F80 M3 (SOLD)
use BMW NEWTIS. search it on google. You have wiring diagrams there.
      10-05-2020, 09:06 AM   #3
pungo
pungo's Avatar
I gotta ask, why? Maybe you only drive in the city? I couldn't do without them.
      10-05-2020, 01:21 PM   #4
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
Hey pungo, so the back story i started with this retrofit with the help from another member on bimmerforum. He did the complete halogen to xenon retrofit on his 17 x3. in order to get the high beam to work it would take a bit more extensive labor running additional wiring from frm to the new headlights. Hence why I decided not to do it and plus where I live I rarely will ever need it. (The guy never activated his high beam either)
Unfortunately they guy who was helping me, he could not get ahold of his coder. That guy is dealing with some family covid issues. So I’m sort of stuck at the moment trying to figure out the ae drl coding myself. And from what I was told it is a coding issue. The rewiring is done correctly as it mirror to the guy that helped me with the retrofit.
      10-05-2020, 06:22 PM   #5
willywi
Drives: BMW x3, BMW x5
Do you have adaptive headlight or not? because they run on different signals. DRL for adaptive uses KCAN3 and non Adaptive uses VCC_TMS signal and LM_LIN_1 for DRL.
      10-05-2020, 06:24 PM   #6
willywi
If you have all the wiring correctly done you only need to add 522 or 552 (depending on your headlight )to your FA then VO code your FRM
      10-05-2020, 06:41 PM   #7
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
The xenon headlights are adaptive.
      10-05-2020, 06:42 PM   #8
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
So what needs to be changed for the coding?
      10-05-2020, 06:43 PM   #9
willywi
You don't need to do FDL coding you only need to do VO coding since this option was available from factory.
      10-05-2020, 06:47 PM   #10
willywi
Adaptive Xenon have 9 pin on the connector and non adaptive have 8.
Adaptive Xenon wiring: https://www.newtis.info/tisv2/a/en/f...ent/1VnZ1oRTJM
Non adaptive High beam, low beam:
https://www.newtis.info/tisv2/a/en/f...her/1VnYkJbpZs
Non adaptive DRL: https://www.newtis.info/tisv2/a/en/f...hts/1VnXkcdPXa
This is X4 pinout but it's the same for X3 they share the same headlight and FRM
      10-05-2020, 07:38 PM   #11
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
Thanks willywi. The wiring is done exactly like the adaptive diagram.
So what parameters need to be change to vo coding?
      10-05-2020, 07:39 PM   #12
willywi
https://f80.bimmerpost.com/forums/at...0&d=1438745738
This guide tells you how to VO code your car.
      10-05-2020, 08:19 PM   #13
ALPx3
ALPx3's Avatar
11
Drives: 17 x3
Pm you willywi
