      02-16-2012, 08:51 AM   #1
cadman50
Drives: 2012 X3 35i, 2021 X3 M40i
Grill patterns on each side below the foglights (35i, non-Msport)
Below the foglights on either side is a mesh-like grill. On the left side the grill is open but on the right side, it's solid plastic behind the grill and attached to the grill. And on the right side, there is just one opening in the upper left corner of the grill. Visually it looks unbalanced with the left side being open. I just picked mine up yesterday and happened to see this. The dealer tells me that all 35i's (non-Msport) are like this and I forgot to look if there were others I could compare to. I can't believe it's wrong but I'm just checking. They tell me the left side is open because of airflow to the turbo intercooler (if I'm getting that terminology right). I wonder why the right side wouldn't be open also.
      02-16-2012, 08:59 AM   #2
bren
user
bren's Avatar
Drives: German Camaro
All the 35's are like that, including msport. Oil cooler on one side and outside air-temp sensor on the other.
      02-16-2012, 09:02 AM   #3
nyalpine90
nyalpine90's Avatar
7431
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
maybe the grill restricts airflow so its left open so free air without restrictions flow right into intercooler/turbos
      02-16-2012, 09:06 AM   #4
Beyu
Drives: 135i
Your dealer is right, the left side is indeed open because of the intercooler behind the mesh, since there's only one intercooler and nothing behind the right mesh there's no need to have airflow going in. If you're bored and decide to look around the car you can also find some air ducts that don't seem to lead anywhere.
Either way it would have been nice if they made both mesh grills open so the car stays symmetrical .
      02-16-2012, 09:13 AM   #5
bren
user
bren's Avatar
Since Lotus isn't around anymore , and just to avoid confusion later - or surprise when you smash into something on that side, it's an oil cooler, not an intercooler.
No. Description Supplement Qty From Up To Part Number
01 Engine oil cooler 1 17217601536
      02-16-2012, 01:08 PM   #6
cadman50
Exactly!! Never noticed it before but when i was looking around the car closely when I picked it up I saw that. It did look strange, especially when the covered one only has a small 'cell' of mesh open and the rest covered. I was ready to say I'm not taking the car because of that defect
      02-16-2012, 01:41 PM   #7
April1
Love All
April1's Avatar
Drives: X3 28i 2011
Appreciate!!!! New Avatar has arrived.
      02-16-2012, 04:05 PM   #8
paul386
Drives: 2011 X3 35i Jet Black
Opening cost fuel mileage. They have it closed to improve the efficiency.
      02-17-2012, 06:51 PM   #9
jsplayin
jsplayin's Avatar
Drives: F80 M3
I don't like the way the closed grill looks on our msport either, I was thinking of using a dremel to open up the holes, but the fuel efficiency comment might have some truth to it.
      02-17-2012, 08:19 PM   #10
paul386
In fact, the 5 series and the 7 series have electrically controlled flap in the kidney grill that closes when the engine doesn't need the cooling to improve fuel efficiency. Openings in the front of the car lead to stagnation points and massive pressure gradients. I'm no aero guy but you can look at pictures of racecars or hybrids and see how the openings in the front is minimal!
      02-17-2012, 10:23 PM   #11
cadman50
Seems odd that the little area on one side only would affect anything since there are alot of openings in the front end anyway. That one is the smallest. Even stranger is that there is one small opening in the covered piece. Maybe they discovered that closing it completely makes a noise or something unusual and just putting a hole in it alleviates the issue.
      02-17-2012, 10:33 PM   #12
Earlofessex
Drives: 2012 X3 35i
That one small opening is for the sensor for measuring external temperature.
      02-18-2012, 10:14 AM   #13
cadman50
I measure it by sticking my hand out the window
      02-18-2012, 11:01 AM   #14
Earlofessex
Drives: 2012 X3 35i
Can't open the windows! That's bad for your fuel economy!
