05-15-2012, 11:53 AM | #1 |
Rep 53
Re coding your X
Anyone feeling a bit frisky, here's something to play around with-
http://www.bimmerfest.com/forums/sho...d.php?t=620626
2013 X3 Msport, White/Black Montana, M-Sport/Prem Pkg, Dynamic Handling, Xenons, Cold Weather, HU, Prem Stereo
05-15-2012, 12:12 PM | #2 |
Rep 1,511
Definitely cool.
I wish I could get the window/roof close with key fob and auto fold mirrors on my car. My old 2004 accord would open the windows with the key fob and close windows using the key in the door. |
05-15-2012, 12:17 PM | #3 |
Captain Amazing
Rep 104
New to coding (w/ BMW); have coded VW and Audi before with VAGCOM.
What cables, tool, software is required to code the newest models?
2013 X3 28i DSB/Mojave/FW
SA, CONV, CW I, PREM, PREM SND, TECH, HUD |
05-15-2012, 12:30 PM | #4 | |
Captain Amazing
Rep 104
What would a quality cable cost on ebay? Or should I look to buy elsewhere If I'm not interested in building one?
05-15-2012, 02:03 PM | #5 | |
Captain Amazing
Rep 104
I have no problem buying the cable off ebay - but I've seen some that are bundled with software, that support the Fxx chassis'. Anyone have any experience with this? Is the software legit? Cable and bundled software was around $110.
05-15-2012, 04:27 PM | #8 | |
Rep 157
This is what you need: http://codecard.lt/electronics/tools.../prod_651.html |
05-15-2012, 08:50 PM | #9 |
Rep 859
05-16-2012, 07:58 AM | #10 |
Captain Amazing
Rep 104
I would think the cable itself would-- USB and OBD - but not the software...
Anyone - thoughts? has anyone tried this? I downloaded E-sys, but need a password/token to install it. And then advice on which site to buy the cable from - Amazon has some for around 50/60 which I think would/could work on the F25...
05-16-2012, 09:40 AM | #11 | |
Rep 157
I've been doing some searching on the coding forum but haven't come up with where I can obtain a token. I think you need to be wary with the cables on Amazon as comments on the other forum suggest they need to be re-configured to work. |
05-16-2012, 10:57 AM | #12 |
Captain Amazing
Rep 104
I will try and search were I got it from- it was a other forum; and it had the token on it I believe- so I do have to find it! Stay tuned. (at work)
05-18-2012, 11:19 PM | #13 |
Rep 323
I would make sure you check up on the cable you're buying if you aren't going to build it. VAG-COM uses a system to connect to the CANBUS in the car, where as in the BMW there's actually a DHCP server in the car which assigns your laptop an IP using the ethernet cable. The software communicates with the car through TCP/IP instead of a USB data connection so it's totally different. The VAG-COM cable has some circuitry and intelligence to establish this connection, where the BMW cable is just a passthrough cable that connects some of the pins to the ethernet pins.
At the very least I wouldn't just buy an OBD to ethernet cable as it may be totally different. Ask for a wiring diagram from the seller and make sure the wires are connected to the right pins and it has the proper resistor as well. |
05-19-2012, 12:16 PM | #14 | |
Love All
170
Rep 740
http://www.bimmerfest.com/forums/sho...d.php?t=619819 |
05-19-2012, 04:46 PM | #15 | |
Rep 157
OK so now have the software, ordered the cable (http://codecard.lt/electronics/tools.../prod_651.html) so watch this space... |
05-19-2012, 07:35 PM | #16 |
*Bimmerpost Plasti Dip Guru*
83
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
This coding would void the warranty right?
05-19-2012, 08:02 PM | #17 |
Love All
170
Rep 740
Why would it void the warranty? Does it void when you de-badge? Does it void when you rewax? Does is void when you change grills or paint calipers? What happens when you add a mod to switch on real fog lights? Many go for new tyres or wheels. Making a setting on or off would never void a warranty. If one changes the torque speed characteristics, that's definitely questionable.
Unless it can be proved that the changes you made are the main causes of a failure or degradation of X3, it is pointless to question if it would void warranty. These are my two cents. |
05-19-2012, 09:01 PM | #18 | |
83
Rep 1,174
After all, ur tapping into the software of the car, which everything is connected n controlled by cars computer.
05-20-2012, 01:09 AM | #19 |
Love All
170
Rep 740
05-31-2012, 04:19 PM | #20 |
Rep 157
OK so the cable came in the post and I have had my first try at coding.
After a few false starts I got everything up and running. There were 2 things I wanted to code this evening, activate the trunk button to close (as well as open) and the Start-Stop memory function. Start-stop worked (no more having to press the button to deactivate each time ) Didnt manage to get the trunk close working though, will try again tomorrow. All in all pretty easy when you have the PDF guides that are available. If anyone else is trying or wants to try feel free to PM me with any questions (not that I'm an expert by an means!). |
05-31-2012, 04:20 PM | #21 |
Rep 323
Did you build the cable or order one pre-made?
EDIT: Just saw your post above where you listed the cable. Wonder if I can get one like that in the US? I'm not afraid of building my own though, I've made so many Cat5 cables over the years I'm pretty sure I could build this thing in my sleep... |
05-31-2012, 04:27 PM | #22 | |
Rep 157
