      08-07-2017, 01:09 PM   #1
dzvero
Drives: 2015 M$4 F82
X3 spare tire question
Hi, Ive been told X3 , X5 spare tire can fit on M4 , Can someone measure the insight diameter of spare tire and post pic of it? I want to be sure before I buy one. thanks
      08-07-2017, 04:52 PM   #2
Lurcher
Lurcher's Avatar
Drives: 2012 z4
No spare, stock has runflats...
      08-07-2017, 06:25 PM   #3
dzvero
You have likely the 3d generation . I think second gen has spare
      08-08-2017, 07:35 AM   #4
Lurcher
Lurcher's Avatar
Drives: 2012 z4
2014 - 2nd gen, no spare...
      08-08-2017, 12:03 PM   #5
MichiganMike
Drives: 2016 X3 xDrive 35i
2020 X3 M40i  [0.00]
2016 BMW X3 35i  [0.00]
The 2nd generation X3 (F25) does not have a spare tire nor space for a spare.
The 1st generation X3 (E83) had a spare tire. If you are interested in information on this spare tire, you might post in the X3 E83 forum.
I found this on the size of the X3 E83 spare tire:
"The E83 spare wheel has part number of 36116758778 for the wheel only (it doesn't seem to be available with a tire). It is steel, 17" diameter, 4" wide with an offset of 18mm."
http://x3.xbimmers.com/forums/showthread.php?t=555635
I am skeptical that this 17" wheel would clear the brake disc and be a good fit on the M4. A 18" temporary spare from the X5 may fit.
http://f80.bimmerpost.com/forums/sho...d.php?t=964023
      08-08-2017, 01:54 PM   #6
dzvero
You are probably right Mike, 17" probably wont work . Thanks
