      05-01-2017, 08:29 AM   #1
vtsng
vtsng's Avatar
Drives: Pre LCI E90 325i SGM
Battery Recommendation
Surprised to see that there aren't many results that turn up on replacement battery recommendations. Looking for a reliable yet cheaper alternative to OEM batteries. Any suggestions will help!
Thanks!
      05-01-2017, 11:15 AM   #2
Tjalle
Drives: X4 35i
Batteries are a bit local - I can't help you there.
Good to know: most X3/X4 have "coast down regeneration": i.e. battery will be charged during coast down - to save fuel. This is a good idea - and not!
To ensure capacity available, generator will not fully charge battery. That is a good thing for - marginal - fuel economy but bad for battery - it will never be fully charged, and hence life is shortened.
This has been discussed before and remedy for me and others is to hook up a CTEK smart charger - or similar - once a month or so. We believe battery life is extended with 100% or so.
      05-01-2017, 01:08 PM   #3
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
I replaced my h8 to a h9 battery recently. I got it from advanced auto which is a larger agm battery, 950cca, 105ah, and 3 yr warranty. Cost was about $150 after discount code. If you change yourself, you will need to register the new battery of course for the larger battery specs.
      05-01-2017, 01:30 PM   #4
vtsng
vtsng's Avatar
Thanks! How is it running to date? Would you happen to have a URL to the one that you bought? Thanks for the tip on the registration as well. I have the Carly app and tool which should be able to register the battery according to the larger battery specs.
Thanks again
      05-01-2017, 01:35 PM   #5
vtsng
vtsng's Avatar
I found this w/ a 20% off coupon @ $175. Looks like you got a great deal!
https://shop.advanceautoparts.com/p/...agm/10866724-P
      05-01-2017, 02:22 PM   #6
ejw2011
ejw2011's Avatar
94
Try trt30 code.
Make sure your x3 will fit the h9 battery as far as length. Mine had a battery hold down bolt that can move to the next slot to fit a longer battery.
Here's the link:
https://shop.advanceautoparts.com/p/...rchTerm=h9+agm
I also used the carly battery registration app @ agm 105ah.
There is no need to supply a secondary power source while disconnecting old battery. The only memory saving lost was just the date/time that can be reset via idrive.
      05-04-2017, 09:22 AM   #7
Barbera335
Drives: F25
I don't know, mine lasted almost six years before I needed to replace it. That is a reasonable amount of time in my book.
      05-04-2017, 08:09 PM   #8
Schmullis
Drives: 2016 X3 3.5i XLine
Sears sells the same AGM battery for $180, just checked
      05-05-2017, 05:01 PM   #9
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
If battery is only supposed to be charged to 80%, then does using external charger to bump up to 100% have any negative affect/compromise reasoning behind normal operation?
Thanks again
Do you have the Pro version? ISTA+ will also register.
      05-05-2017, 08:55 PM   #10
///Mposter
Macgyver
///Mposter's Avatar
Drives: 2007 e92 335i
Thanks again
The battery isn't suppose to be charged to only 80% but that is most likely the threshold at which it is acceptable.
People who drive shorter distances have a more aggressive regen braking. When it reaches back up to 80% then it returns to normal charging.
I can tell you by personal experience , after a new battery ...wow! Car drives better. Not such an aggressive regen brake. Mileage went up a lot! Radio stopped losing its memory at every start up, heated seats work fast versus after 5min on old battery, weird stumbling at idle gone, and probably more I can't think of at the moment. 6 years on mine and I used a CTEK for the whole last year.
Almaretto2374.00
      05-05-2017, 09:01 PM   #11
///Mposter
Macgyver
///Mposter's Avatar
Forgot to mention that I also hooked up the foxwell to the coupe after registering the battery on the X3 and these were the values stored. Notice when I used the CTEK charger.
      05-08-2017, 04:42 PM   #12
matt@bavsound
Drives: 2005 330i
Interstate batteries are incredibly good and have a true lifetime no questions warranty. I pulled one from a friend's used Lexus, put it in our 4Runner, and it lasted 2 years - at which point I went to an Interstate dealer and got it swapped for a brand new one. No receipt.
It's been going strong for 4 years since.
Optima batteries are also pretty great, but at that price point I'd do an Interstate any day.
Hope this helps!
      08-14-2017, 05:40 PM   #13
punch1118
Drives: 2011 X3
I have a 2011 with original battery
thats right 6 full years of service and counting
however it might have something to do with low miles (35k)
our local batteries+ has a duracell 49r 92ah agm for $229-10% in stock whenever I need it
at this point all you would need is an indy registration (no coding)
or do everything yourself (my local bmw dealership wants $75 for registration only...they won't do coding for a battery with different specs)
the new battery matches specs of the original which is the best and easiest way to go in my book
the genuine bmw battery would be $245
