      07-05-2012, 03:15 PM   #1
cadman50
Drives: 2012 X3 35i, 2021 X3 M40i
Moving shifter to left vs. buttons on left of shifter
Manual doesn't seem to explain this much. If I slide the shifter to the left only I'm in Drive Sport mode. As far as I can tell, this only seems to affect the shift points. So is this the same as going from Normal to Sport and configure sport mode with Drivetrain only? Both ways you can enable manual shifting by using the paddle shifters.
      07-05-2012, 09:12 PM   #2
Beyu
Drives: 135i
You are correct, sliding the shifter left simply changes the rpm shift points. However, this is not the same thing as having "drivetrain enabled," drivetrain not only changes the shift points but also increases throttle response. You can test this by having the shifter in left position then turn on sport mode, you'll notice that the rpm stays the same but you'll suddenly accelerate.
Without the shifter in left position manual shifting is only temporary, the car will revert back to auto after a few seconds.
      07-05-2012, 10:36 PM   #3
xDrive35i
xDrive35i's Avatar
Drives: Porsche Macan S
Moving the shifter to the left does change shift points but also changes throttle response. Switching to Drivetrain Sport will do this with even greater effect, but shift timing will also be slightly quicker and more abrupt as a result.
      07-06-2012, 02:19 AM   #4
nonagon
nonagon's Avatar
Drives: Porsche Cayenne GTS
And the car stays in gear when shifting manually when shifter is to the left.
      07-06-2012, 02:23 AM   #5
Ural
Ural's Avatar
Drives: 2011 X3 20d
Also, in sport mode steering becomes stiffer and therefore more responsive even you opt 'drivetrain only'. DS mode doesn't do that.
      07-09-2012, 09:53 PM   #6
cadman50
Been out of touch lately and just reading these. Thanks for the replies! I guess sliding the shifter to the left in DS mode is kind of like SPORT 'lite'.
