01-20-2016, 12:05 AM | #1 |
Rep 12
Drives: 2015 X3 xDrive28i
Kidney Grille Swap
I know this is an extremely simple DIY, but if there is anyone out there like myself, you like to see how somebody else did something (and probably made mistakes you can avoid) before doing it yourself. Plus I figure its a good way to give back to online forums that have kept me afloat through all my busted up car owning days.
I decided to go with the all black look. Not 100% sure about it yet but I'm letting it grow on me to see if it sticks. Regardless if you're looking to change out or maybe paint/modify your current set up, I hope this can help. Also gives me a chance to open the discussion for black grills on BSM. 1.) Remove the rubber weather stripping 2.) Take a T25 screwdriver to remove the 6 screws holding the grilles in place 3.) Take a long and preferably skinny flat head screw driver and depress the 3 clips that hold the grille in. I started from the center and worked out. There are multiple other pressure clips, but these three actually need to be pressed in to release the grille. You can see the clip positions below. 4.) Gently maneuver the grille until it pops out. (It is pretty straight forward, just don't yank and twist because the plastic clips will probably just break.) 5.) Reverse process until you put the weather stripping back in. Easy. |
01-30-2016, 07:54 PM | #5 |
Rep 54
Is there any need to pull the bumper forward to reach the top clips? I've read in old threads that after you get the screws off, you have to pull the bumper forward slightly in order to slide your hand behind the grill to pop the clips off.
Is this not so on the LCI? |
02-04-2016, 04:12 PM | #6 |
IG @bmwF9xG80
3813
Rep 7,593
Looks good, i decided to plasti-dip it instead =D
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-05-2016, 04:38 PM | #8 |
Rep 560
That's a good idea and presumably you can peel back to original if you wish.
I wonder why no one has wrapped them as this could also be changed back if needed. I have seen some great looking carbon fiber black wrap that would look good on them! I have no experience of wrapping, but I wonder if they could be done without removing the grilles? |
02-06-2016, 10:22 AM | #9 | |
Rep 12
02-06-2016, 10:26 AM | #10 | |
Rep 12
I'll post that DIY soon hopefully so people can learn from my many mistakes. Roof rack looks much better in carbon fiber though. |
03-01-2016, 11:32 AM | #11 |
Rep 2,808
03-01-2016, 12:08 PM | #12 | |
Rep 31
sorry to resurrect this thread but I'm about to attempt the grill swap. Just had a question about step 1 below, the removal of the weatherstripping. Does it just pull off like in the pic? is there anything holding it onto the car?
04-16-2016, 02:18 PM | #13 |
Rep 53
Thanks for the photos and descriptions. Although I prefer OEM on my LBB car , I am thinking of wrapping the silver mirror caps and front winglets in CF.
04-16-2016, 06:11 PM | #14 |
Rep 363
@alleyooptroop it's a push on fit, so get your fingers under it and prize away from the chassis. To replace, line up the plastic mounts and push down
05-05-2016, 08:56 AM | #15 |
Rep 3,742
Bumping this old thread: How are you guys releasing the three clips on the bottom of each grille? The top three can fairly easily be reached when you remove those six torx fasteners, but I don't see any way to get to the bottom three.
Not sure if something changed on the design from whatever car was used to make this DIY but I am not seeing how these things are coming off without removing the bumper (which I can do, but it will be a PITA). |
05-05-2016, 11:38 AM | #16 | |
Rep 2,808
05-05-2016, 05:31 PM | #17 |
Rep 3,742
Yes, thank you for posting that. It was a bit confusing because you showed a picture of a hook-like object but your directions referenced special pliers (which I don't have). What did you use to make the hook? A coat hanger?
It's hard for me to imagine a coat hanger being rigid enough to release the tabs instead of just bending. The top ones seemed very stiff and it took quite a bit of pressure to release them even using a screw driver. |
05-06-2016, 08:13 AM | #18 |
Rep 90
Take a look on x4 thtread, it may help. once you have undone torx bolts and released top clips by prizeing grill gently forward. I bought aset of plastic trim removal tools on e bay, just the job, once you have released top clips, which is the hard part, now have easy access to bottom clips and use plastic tool to release, I say again PATIENCE is the Key, good luck.
05-06-2016, 09:44 AM | #19 | |
Rep 3,742
05-06-2016, 12:20 PM | #20 | |
Rep 2,808
The one thing was that for the life of me, I could not get at the 3 bottom clips on the grills, and almost tore up my wrist in doing so. I have no idea how others have been able to do it. So I came up with this J shaped tool, which I made out of a small copper tube. And then the 3 clips came undone in like 30 seconds! I think it was an old air conditioning tube or something in its old life. Yeah, it needs to be something stiff. Some coat hangers are thicker wire than others, so it might work for you. Good luck. |
05-06-2016, 01:00 PM | #21 | |
Rep 3,742
Tags |
black, blackout, bsm, grille, kidney grille glossy piano black |
