      11-10-2011, 11:43 AM   #1
sard
Drives: 2008 M3
BMW Jack Pad?
Hi, anyone know of a solution for you to be able to use both a hydraulic floor jack and a regular floor stand on the BMW jacking points?
Items such as the ones with the rectangular adapter that insert into the jack point with a flat round other side will work with the hydraulic floor jack, but seems unstable with the floor stands with a "U" type of top to it.
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo
      11-10-2011, 02:30 PM   #2
sard
Drives: 2008 M3
Thanks Lotus
      11-10-2011, 02:32 PM   #3
LEDZEP
LEDZEP's Avatar
418
Drives: 2009 E70 & 2011 F25
Okay, I'll ask the dumb question.
If you're going to put the jack stand under the jack point.... where are you placing the jack in order to do that?
I think it is bad luck to be superstitious
      11-10-2011, 02:45 PM   #4
jsublime
Drives: G20 M340i
2015 BMW X3 28i  [0.00]
2011 BMW 135i  [0.00]
2016 BMW M3  [0.00]
Originally Posted by Lotus7 View Post
A good solution for using jack stands at the BMW jack points is to cut a piece of aluminum 1-1/4 X 1-1/4 bar stock (any alloy is fine I've used plain old 6061) to 2 inch lengths. It fits the X3 jack-point socket and sticks out enough to safely be supported by a small jack stand.
McMaster-Carr sells 6061 bars 12 inches long for $18 (P/N 9008K151). One piece of the 1-1/4 X 1-1/4 bar will make (6) X3 jack point supports. All you need is a sharp hacksaw and 5 minutes to cut it.
I suppose you could make a insert out of hardwood like oak, but aluminum is certainly stronger and will hold up better to repeated use.
Thanks for the great suggestion.
The other jack point
One the 1 and 3 series there is a central jack point between the two front wheels, does the X3 not have this?
      11-10-2011, 03:21 PM   #5
walendvay
Drives: '11 F25 28i; '13 E84 35i
hockey puck
http://www.bimmerfest.com/forums/sho...d.php?t=481910
      11-10-2011, 03:33 PM   #6
LEDZEP
LEDZEP's Avatar
418
If you jack it high enough via the front jack point you can put a [lower] jack stand in the other one on that side. You can get both wheels on one side off the ground that way.
To get the car on (4) jack stands, you have to be VERY, VERY quick to remove the floor jack and put a stand in it's place.
LOL. That's what I was picturing when I was reading the OP.
Did you ever try that center mount point beneath the engine? I considered trying it, but chickened out. It is really not sized properly to accept a jack stand.
      11-10-2011, 04:18 PM   #7
walendvay
ah, shot down, yet again!
the hockey puck works well with a 3ton floor jack. I place stands on other parts of the rig.
I am just providing suggestions. They work for me and work well!
      11-10-2011, 05:15 PM   #8
Radioactive
Drives: '11 X3 28i '10 535i '04 325i
How about getting some railroad ties and cross stacking them like they do on heavy equipment.
Damn car manufactures keep making it harder and harder for the DIYer
      11-11-2011, 06:02 AM   #9
walendvay
Well put! That's where these forums kick in!
      11-11-2011, 09:20 AM   #10
Radioactive
I'm convinced it's by design. Maybe I'm paranoid, but I sincerely believe that most, if not all car manufacturers do not want any independent repair shops and especially owners to have any access to working on "their" (note, I used “their”, not "our") cars. That attitude MAY be morally acceptable while the vehicle is under warranty, but once that warranty has expired , it’s clearly a way of forcing all owners back to the dealership and is a form of anti-competitive protectionism, that’s almost criminal.
It wasn't that long ago that you could purchase a detailed repair manual for any new car with the blessing, and help of the manufacturer for very low cost. All US car brands usually included an order form for the service manual in the Owner's Manual. Then, starting about 15 years ago, service manuals suddenly increased in price from $10 or $15 to several hundreds of dollars. The next stage was about 10 years ago when the only way to get a service manual was in PDF form on a CDROM, and only if you had a dealership "connection". Now service manuals are not made available to the general public AT ALL and in BMW's case are only available to dealerships on-line via secure on-line subscriptions so they can't be duplicated on CDR's. They're treated as proprietary information and guarded as though they contain the pass code to Bill Gate’s bank account.
Clearly, BMW, and most other new vehicle manufacturers, do not want anyone but their own shops having the capability to work on these cars. Clearly, it’s in their best interest from a service related profit point of view to do everything they can to keep other’s from being able to work on the cars.
I've been told by both a Ford service manager and an independent BMW repair shop owner that the cars are now designed for the average owner to be difficult to work on. If fact the service manager told me that Ford purposely made the oil filter difficult to access and the BMW guy told me that within a few years he will not be able to work on the newer BMW's.
If my memory still serves me, the manufactures use to have repair manual order information in the back of the owner's manual.
      11-16-2011, 07:15 PM   #11
sard
Drives: 2008 M3
Thanks Lotus!
      11-16-2011, 09:23 PM   #12
Bogiegolf
Drives: 2011 X3 3.5/2013 135is #562
I took Lotus' advice and ordered one of the Reversol (sp) specific jack tools and also odered 2 blocks from the online materials website.
Now, if I only knew where the jack and jack stand came from, I would be all set to install some mud flaps.......
      11-25-2011, 02:07 AM   #13
mdtmem
Drives: 2012 BMW X3 35i M Sport
ECS Tuning also makes a adapter but I prefer the reverselogic one better. The ECS Tuning one I had first & used with my previous BMW's but it did not have the little rubber circles to hold it in place. So, you had to slowly lift the jack & hold the adapter until the floor jack was to the height of the car.
2011 Mercedes Benz GL 550
1997 Panoz AIV Roadster
      11-25-2011, 08:02 PM   #14
fvfvsix
Drives: '22 M3 | '22 X3 M40i
Another option is to use ESCO jack stands with the flat tops. These will work with the reverse logic jack point tools.
      12-04-2011, 07:16 AM   #15
Bogiegolf
Floor jacks and jack stands are readily available from suppliers like Harbor Freight, Sears, and on-lne outlets like Amazon.com, as well as retail auto parts stores like Pep-Boys, Autozone and O’Reilly auto Parts.
Will a jack with a 15" lift be enough to lift both wheels at the same time?
      12-04-2011, 07:37 AM   #16
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Yes, good suggestion. The ESCOs are perfect for use with the Reverse Logic Jack Point Tool if you don't already have jack stands.
ESCO stands can be ordered from Northern Tool. The part number is 146640. ESCO Model No. is 10498.
This is how I do it, and the dealer here in the UK does the same, they do not have these blocks!!.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      09-17-2012, 09:13 PM   #17
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
Wow, that is cool. Anyone try the hockey puck on a F25?
Originally Posted by walendvay View Post
      09-17-2012, 11:00 PM   #18
02420X3
Drives: 2011 X3 35i
Nope. I bought my jack pad inserts from Reverse Logic. See my reply to your other post.
      09-18-2012, 11:18 AM   #19
DonC
Drives: 2013 X3 3.5i M sport, etc
Just ordered "stuff" from Reverse Logic.
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
