      08-29-2011, 07:11 PM   #1
canzilla
canzilla's Avatar
Drives: 2020 X3M
Narrower winter tires on M-sport wheels?
Anyone knows if I can use narrower tires on the M-sport wheels(369M)?
Looking for a set of ROF winter tires to replace the Goodyear LS2.
Already check on tirerack, but I cannot find any thing that is narrower than 245.
Any suggestions will be helpful.
thx
      08-29-2011, 09:23 PM   #2
utcadman
Drives: X5 M50i
The make the Blizzak LM 60 in the OEM 245/45-19 not ROF but probably the best snow performance...
      08-29-2011, 11:17 PM   #3
canzilla
canzilla's Avatar
Drives: 2020 X3M
Agree, but I want to know if I can use narrower tires as an alternative.
Narrower tires are cheaper and better to drive in the snow.
      08-30-2011, 02:04 AM   #4
richardew
richardew's Avatar
9
Drives: 2011 x335i
I've been driving the past 7 winters with OEM sized winter tires on an 911C4 cab and 335XI w/sport package. I went -2 on an FX45 because that was the largest winter tire I could get in '04. I have never had any problems driving through the snow. IMO ground clearance is going to be more of a limiting factor than the width of the tires. I think you'll do fine with OEM sizes.
Rich
'96 911 C4 Cab (276,000 1 owner smiles)
'11 X3 35i Black Sapphire/Beige,SAP, CP, CWP, DHP, PREM, TECH, Sat radio, Hi Fi, BMW apps, smartphone, 19" w/mixed performance tires.
      08-30-2011, 04:51 AM   #5
Nahoa
Don't you have to get narrower wheels to use narrower tires?
      08-30-2011, 09:47 AM   #6
richardew
richardew's Avatar
9
Drives: 2011 x335i
Not necessarily. There are a range of widths that will fit a particular width rim.
Rich
      08-30-2011, 03:53 PM   #7
Nahoa
I had no idea of that. Interesting. What defines the range? Something you look for on the specs of the wheel? Or is it more a tire that fits a range of wheels? This is true with RFTs?
      08-30-2011, 11:34 PM   #8
canzilla
canzilla's Avatar
Drives: 2020 X3M
Thx
If the price for narrower tires is not much different, I will stick with OEM size.
      08-31-2011, 12:24 PM   #9
LEDZEP
LEDZEP's Avatar
417
Drives: 2009 E70 & 2011 F25
You should be able to find Blizzaks that are run-flats. They have them in most sizes.
I think it is bad luck to be superstitious
      08-31-2011, 12:42 PM   #10
richardew
richardew's Avatar
9
Drives: 2011 x335i
I am no tire expert. Rims seem to be sized in 1/2 inch increments. Tires are in 5 mM increments. The reps at tirerack can answer the question what tire will fit in what rim.
Rich
      09-01-2011, 03:02 AM   #11
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
thx
I have on order Dunlop winter sport 100V XL Run-Flats, these will go on Team Dynamics Pro-Race 1.3 Alloys 18" * 8.5" all round.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      09-01-2011, 06:35 AM   #12
XB101
Drives: 2011 TiAg X3 35i
On Tire Rack it mentioned we need the new TPMS. My agent said the sensors are built into the system and not mounted on the wheels.
      09-01-2011, 06:55 AM   #13
Lotus7
Drives: xxxx
If your "agent" works in the service department, I'd look for a different Service Dept. If that statement came from a CA, I'm not surprised since they often don't have any understanding of the vehicle from an engineering viewpoint.
The F25 X3 Tire Pressure Monitoring System (TPMS) uses a battery powered transmitter mounted in each wheel (cost: About $50 each from Tire Rack). Pre mid-2006 E83's used the "less accurate, indirect", wheel speed sensing system, but after 2006 BMW went to real pressure monitoring instead of the older indirect method. When the F25's came out the frequency of the RF transmitters was changed, so although the E83 transmitters look like the new F25 transmitters, they won't work with the newer system.
The only "sensors built into the system" are the pick-up antenna boxes adjacent to each wheel, that work in conjunction with the wheel's internal transmitters. Mounting aftermarket wheels without TPMS transmitters, will, of course, disable the TPMS.
If you want the vehicle TPMS to work, you must invest in a set of transmitters. With "normal" use, the batteries are expected to last 5 or 6 years. There is a kit to replace the batteries, a process that also requires some gasket replacements.
      09-01-2011, 04:01 PM   #14
fedinand
fedinand's Avatar
Drives: '11 X3, '11 GTI
Here is the spec sheet on the Blizzacks - look at the column that says rim size and it will give you a range of appropriate rim widths. The higher the sidewall the more leeway you seem to have...
http://www.tirerack.com/tires/tires....omCompare1=yes
