      03-26-2014, 01:09 AM   #1
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
Intermittent AC compressor noise
I had to record this video so I would have evidence of a faulty a/c compressor clutch when I take my car in... the noise is intermittent and I fully expect the car to behave when I take it in for service.
What do you guys think? Compressor clutch?
[/u2b]
      03-26-2014, 12:11 PM   #2
cvandenhaute
cvandenhaute's Avatar
Drives: '11 BMW 128i, '19 Genesis G70
May be the same issue I had with my 1 series: I had a leak in the condenser (known issue) which was causing the compressor to run too hard and had a pretty similar sound, I would get it to the shop right now for checking
128i manual, AW, Boston Terra Leather, Sport package, Premium Package, Cold Weather Package, HK sound
      03-27-2014, 02:38 PM   #3
lbjgh
lbjgh's Avatar
cvandenjaute,
Since my car is under warranty I would prefer a failure than a cobbled together repair now. If there is a leak (and damage) I wouldn't want the leak fixed only to have a mechanical failure outside warranty.
      03-27-2014, 05:30 PM   #4
cvandenhaute
Originally Posted by lbjgh View Post
cvandenjaute,
The good thing is that if the issue is the one I described, it would be taken under warranty (trust me it is a big one, since they have to remove all the dash board and front consoles) and the repair is backed up by 2 years warranty, which should cover you out of warranty if the problem was to happen again...
      03-28-2014, 07:39 AM   #5
Rodion
Finland
27
Drives: X3 (F25)
Mine has similar noise, but not that loud and maybe in lower hertz. I mean not that high pitch noise.
I have complained two times and it was checked by mechanics and they say it is normal noise.
Even though the cars they gave me (3 series and 5 series) didn't have that noise when "playing" with compressor on / off.
Well, if it blows up, I have in writing that I have been there two times complaining -> should be no problem getting it fixed with their money, not mine.
      05-29-2014, 07:28 PM   #6
Akview
Drives: 2013 X3 28i 2018 530i
2013 X3 28i  [0.00]
My AC low pitched whine
I've noticed an intermittent low pitched whine that goes away when I hit the snow flake off. Only notice when slow and less road noise and related to engine rpm. Turn on the radio or go faster it's gone. So I found solution drive fast with radio turned up
I was told it was normal. Even though they have replaced a seal after lost freon. I questioned that compressor had been damaged. Told not probable.
I guess it needs to stop working before they will fix it.
I think I will record the sound too.
      05-30-2014, 12:16 PM   #7
lbjgh
lbjgh's Avatar
Well I just heard back from the service adviser an hour ago... after waiting over two weeks for an appointment to look at the A/C, do an oil change, brake fluid flush and moonroof creak the dealership blew off my appointment.
They claimed they were really backed up. So, since I booked my appointment two weeks ago I can only assume they are working on cars from three weeks ago!
Oh, and they had the nerve to try up-sale a wheel alignment and a fuel injector flush when my wife dropped of the car! When the hell were they planning to do the extra work when they can't even do the warranty work.
I'm pissed, it's getting hot and my car has no A/C.
What a Mickey Mouse operation at Maranello!
      06-05-2014, 01:29 PM   #8
lbjgh
lbjgh's Avatar
Update.... a new condenser is being installed today.
I wonder if the condenser is known faulty component??
