02-23-2017, 11:05 AM | #1 |
Rep 396
Offset Question
Quick question guys,
If i'm getting aftermarket wheels, what offset should i get so that its flush and i don't have to get spacers for 19" wheels (non staggered setup) |
02-23-2017, 12:27 PM | #2 | |
Rep 741
http://x3.xbimmers.com/forums/showthread.php?t=666241
['13 X3 SGM] [20" XXR550's in Black Chrome] [Lamin-X Tails/Fogs] [M-Sport Rear] [FOX Exhaust][H&R Sport Springs][RaceChip Ultimate][BMS N55 Intake]
SOLD-['06 325i TiAg] [19" VMR VB3 HYPERBLACK] [Blacklines] [OEM Xenon Conversion] [35% Tint] [M-Tech Rear] [M-Tech Front] [Black Vinyl Roof] [Slotted/Drilled Rotors, Cool Carbon Pads] [PBX] |
02-23-2017, 03:39 PM | #4 | |
Rep 236
1. Of course the offset of the given wheel 2. the width of the wheel itself e.g. 8.0 8.5, 9.5, 10.0. So for example a 30mm offset is completely different on a 8.5 than on a 10.0 wheel 3. the the thickness of the wheels outer lip will also have an impact on how flush the wheels will look Besides all of these points, a lot of the time, people will want to finetune by adding 5-10mm spacers to perfect the appearance. Furthermore, wheels are not available in all possible offsets and widths, and not all offsets are street legal.
BMW X3 G01 Alpine White
02-24-2017, 10:53 AM | #6 |
Rep 236
No not really.... As mentioned above, it depends on you wheels.
Check you the pics on this thread as a reference and take it from there: http://x3.xbimmers.com/forums/showth...ht=anus&page=2 You can see what my x3 looks like with 12mm in front and 17mm in the back. That is in combination with 369M wheels: 8,5J x 19 ET38 and 9,5J x 19 ET48. So what does that mean? Well if you take same wide wheels: Front 8.5" => Offset 38 minus 12mm spacers = 16mm Offset Rear 9.5" => Offset 48mm minus 17mm spacers = 31mm Offset. So the effective offset you see on the pics are 26mm in front and 31mm in the back. So if you want flushness like on my X3 your gonna need around 26mm offset on a 8.5 and 31mm on a 9.5mm wheel. As an other example: http://x3.xbimmers.com/forums/showthread.php?t=666241 That guy has 10" rear wheels with 51mm Offset. He put 12mm spacers in the back, so he has a new offset of 51minus 23mm = 28mm. His front wheels have the same offset and width as my wheels: 38mm minus 12mm = 16mm Hope this helps... You're gonna have to do the maths yourself based on your wheel configuration. By the way.... in some countries an offset of less than 10mm is illegal.
02-24-2017, 03:45 PM | #7 |
Rep 396
Good to know, thanks! I think you meant you have 26MM offset in front not 16?
I think my wheels are 8.5 x 19 ET 38 all around right now. Non staggered M-pkg setup? My buddy was just saying that he undersatnds why people put spacers on standard factory wheels, but if you are going aftermarket, he says why not just get the right wheels lol |
02-25-2017, 04:38 PM | #8 | |
Rep 236
02-26-2017, 12:27 AM | #9 |
Rep 983
Back when the F25 X3 was new, we had an expert with detailed knowledge. He is no longer available, but some of his knowledge is. Here is what Lotus 7 had to say about offsets:
BMW Wheel Offsets The correct offsets for the BMW factory wheels are: 307, 308 & 368 wheels 8JX18 ET43 (42 to 45 recommended range for 8.0 wheels) 309 & 369 wheels (Fronts) 8.5JX19 ET38 309 & 369 wheels (Rears) 9.5JX19 ET48 All, of course, have 72.6 borecentric mounting with a 5X120 BC. Unlike most other BMW's the F25 chassis uses 14X1.25mm straight-tapered seat bolts instead of the more common 14X1.5mm bolts. The wheel bolt holes are the same, but the bolts obviously won't interchange. M3 wheels vary with the year, but many have an offset between 30 and 40 mm for typical 8 or 8.5 widths. The 40's are probably OK , but 30's would be hard on the wheel bearings and might have clearance problems. |
03-02-2017, 04:34 PM | #10 |
Rep 396
03-02-2017, 04:44 PM | #11 |
Rep 236
Nice wheels. I'd put 12mm on all four wheels paired up with pirelli p zero non-runflats.
03-02-2017, 04:53 PM | #12 | |
Rep 396
Thanks! I know you did 12's on the front but this offset is 35 vs stock 38 i think, so maybe 15's on the front would be better. And probably just do 15's in the back then too Last edited by alpwhite46; 03-02-2017 at 05:53 PM.. |
03-02-2017, 11:28 PM | #13 |
Rep 983
From Lotus 7:
03-04-2017, 12:09 AM | #14 |
Rep 735
Just waiting for my new Niche Vicenza wheels to arrive ...
20x9 et35 w/ (stock size tires non-RF) 245/40/20 20x10 et40 w/ (stock size tires non-RF) 275/35/20 OEM is: 20x8.5 et38 20x10 et51 compare at: http://www.e90post.com/forums/forumdisplay.php?f=12
Current ///M: 2017 M3 Ultimate Past ///M Cars: E92 M3 ZCP 'CDN LRP' … E85 Z4M-R ... E92 M3 ZCP Frozen ... E90 M3 ... E46 M3 Cab ... E46 M3 ZCP ... E46 M3 |
