      05-18-2012, 01:58 AM   #1
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
Jacking Car?
I have a 2 ton hydrolic jack that I just bought. Wanted to make sure if its ok to lift one wheel of the 2013 f25 28i which is 4100 something pounds.
I'm waiting on the adapter to come in.
Thankies!
      05-18-2012, 03:40 AM   #2
brissim
Drives: X3 30d (2011 F25) - now sold
Well do the maths - 2 ton = 4,480 lb.
And when you jack up a car you also have weight on the three other tyres. So 2 ton should be OK. I've only got a 2 ton jack (well 2 tonne to be exact) and have had no issues in my practice runs.
One of the important things to check is the minimum height of the jack. Using a Reverse Logic adaptor, I only have around 200mm (8") clearance under the jacking point. And if your jacking up to replace a flat tyre, it will be even less than this - probably around 180mm (7").
Also make sure you get some wheel hangers - it makes the removal/replacment of wheels much easier.
Tony
      05-18-2012, 07:04 AM   #3
n55x3
Drives: n55 BMWs
2 ton jack is more than enough. Just don't forget the most important rule JACK STANDS!
      05-18-2012, 07:20 AM   #4
KingX
Unregistered
KingX's Avatar
Drives: 2013 X3 M-Sport 35i
Tony
Where did you pick up your wheel hangers?
2013 F25 X3 35i M-Sport
[Black Sapphire/Oyster/Wave Wood: ZPP/ZTP/ZCW/ZCX/ZDH/ZPS/ZMP/6NR]
      05-18-2012, 07:42 AM   #5
02420X3
Drives: 2011 X3 35i
I got mine from Reverse Logic, the same place that I got my jack point inserts.
http://www.reverselogic.us/ReverseLo...ide_Tools.html
      05-18-2012, 10:08 AM   #6
Teemo Panda
2013 BMW X3  [5.66]
Tony
Oh really? I thought a ton is 2000 pounds, was worried about the excess of 100lbs will affect the jack itself.
Thanks guys for the insight and info!
The reason why I asked this question is that, I wanted to paint my wheels with plasti dip :P.
Also this would help other DIYers
      05-18-2012, 12:18 PM   #7
02420X3
Drives: 2011 X3 35i
English-speaking countries are both joined and separated by our common language. Depending on which Ton (or Tonne) you're talking about, it can be 2,000, 2204.6, or 2240 lbs. Your jack is likley rated for 4,000 lbs., while Brissim's Oz jack is apparently rated for 4,480 lbs. Either way, you're both jacking up only one corner of the X3, and a 2-ton (or tonne) jack should be fine. Still, use of safety equipment such as jackstands is always a good practice.
If possible, would you mind doing before and after pics of one of the wheels.
      05-18-2012, 01:08 PM   #8
Teemo Panda
2013 BMW X3  [5.66]
Thanks bro!! Will do on the safety measures.
      05-18-2012, 04:14 PM   #9
brissim
also Reverse Logic. Thank you Lotus7 - gone but not forgotten.
Tony
