07-15-2013, 05:47 PM | #1 |
Rep 1,511
whirring noise when accelerating
Recently my car has started to make a whirring noise when accelerating. It seems to happen under moderate acceleration when the car is warmed up to operating temps.
Maybe a bad bearing but the pitch changes with each gear change. To me it sounds like it may be an accessory driven part because when I disable the a/c and radio I can't hear the noise. (no it isn't radio static) ...so at this point the noise is somewhat erratic. The next service for the rear brakes is in about 5000km so hopefully the car will fix itself (not likely) or the part that's making the noise fails or gets worse making it easier to diagnose. Anyone else have a whirring noise?
07-19-2013, 06:06 PM | #2 |
Rep 1,334
I have a whirring noise of sorts with moderate acceleration. It only happens roughly between 2-3.5K RPM. For example I'll start accelerating in 1st gear and I wont hear it until about 2500 rpm..then it stops by 3500 rpm. It'll change to 2nd gear and as it's climbing back up I hear it again at about 2500-3000 rpm and it stops again at around 4000 rpm. I made a little video long time ago and posted it on this thread. The dealer said they couldn't hear it. Although I can reproduce it every single time. Sometimes you just don't care enough to bother with it.
E92 M3 - DCT - 20" BBS LM-R - KW Clubsport - Akrapovic Exhaust - Powerchip Tune - Arkym Aero Kit - HID Halo |
07-19-2013, 06:38 PM | #3 |
Rep 2,602
To me, I think I hear an auxilary fan at times.
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
07-19-2013, 09:06 PM | #4 |
Rep 1,511
I've narrowed the noise down the the AC accessory belt or AC compressor clutch. I pretty much expect the dealership to be "hard of hearing" when I bring the car in to be checked out.
07-22-2013, 03:17 AM | #5 |
Rep 350
Do you hear it while lifting the gas pedal up and slowing with "engine"?
I have that, as well as when at idle or accelerating, and it disappears when A/C is off. So it must be something with the AC compressor. Maybe it is dry and makes a little noise because of no lubrication in it. Or the engine itself is now quieter and that is normal AC compressor noise. |
07-22-2013, 11:25 AM | #6 |
Rep 1,511
If you have ever driven a vehicle with a faulty bearing you'll recognize the noise.
The noise is synchronous with the engine RPM when the AC is engaged.
07-23-2013, 03:10 AM | #8 | |
Rep 350
So the problem must be within the AC compressor. Or, then again, it is not a problem, it is a feature... |
07-23-2013, 09:38 AM | #9 |
Rep 1,511
Rodion,
I think your problem is that your hearing is better than the BMW technician's hearing.
11-04-2013, 09:46 PM | #10 |
Rep 14
has anyone found what caused the problem and got it fixed. Thanks
BMW F25-X3 xDrive 20d
Carbon Black, M Sport Package, Nevada Leather Oyster, Navigation System... |
11-05-2013, 09:04 AM | #11 |
Owner
132
Rep 566
Drives: G05 30d M-Sport
I also sometime hear a whistling noise, even when the AC is off. However, I suspect the AC is never /entirely/ off... It's definitely not turbo (it's at quite low regime). And it's not all the time.. Been wondering about it for a while...
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
02-09-2014, 06:14 PM | #12 |
Rep 5,457
Mine does it, started recently, my 2011 X5 35i did it also. The X5 did it soon after noon and I figured eventually something would break, never got better or worse for 3 years and traded it on the X3, now the X3 does it.
Going to go with normal at this point!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
02-11-2014, 03:29 AM | #13 |
Owner
132
Rep 566
After many more hours of listening, it only does it when the car is warming up. Once it reaches temperature, it stops. Still sounds wierd...
08-29-2016, 10:09 AM | #14 |
Rep 64
Reviving old post- My 2010 diesel would make a whistling whirring noise- found my exhaust gas pressure pipe-rubber piece on pipe split- part # 13627812806 - replaced that - all good.
12-07-2019, 11:11 AM | #15 |
dscollins
Rep 35
Hi my bmw x3 f25 auto as been making a whirring noise for some time now seems when its reached operating temperature, theirs no change in noise if a/c is on or off more noticeable at low speed , the noise seems to come from passenger side of car uk model,
12-07-2019, 01:23 PM | #16 |
Rep 1,044
I've been told that sometimes the tensioner pulley can make noise when it is starting to go out.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
01-31-2020, 01:53 PM | #17 | |
dscollins
Rep 35
BMW 2.OD AUTO 2014 Whirring Noise
10-07-2021, 11:50 AM | #18 |
Rep 1
Subscribing to this thread. Maybe some solutions will emerge in time.
The N20 on our F25 is making the sound when the AC is on. Goes away when shut off. Car is new to us and 128k miles. I'm guessing either the belt system driving the compressor, or the compressor itself (bearing and/or low on refrigerant). Will update if I dig into it. |
