08-31-2016, 01:34 PM | #1 |
Rep 66
Permanent live in front fusebox
Hi all,
Im trying to fit a power magic pro for my dashcam. It needs to be in the front fuse box. Ive found a live circuit which powers off as soon as you turn off the car. However, Im struggling to find a permanent live.....almost all of the fuses stay live for around 30mins after the car is turned off. Problem is, how on earth do I find a front fuse that stays live all the time? Not sure how Im going to do it other than weeks of trial and error....... Unless anyone on here knows which front fuses offer a permanent live? Thanks in advance. |
09-01-2016, 04:56 AM | #5 |
Idiot-in-chief
31
Rep 218
You should be able to tap into a permanently live wire anywhere in the car that you can find one (you can use an in-line fuse)
I've got notes on BMW wiring that say Ignition Switch position 0 - off position I - accessory position II - on position III - start In general: (test first with a multimeter just in case it's different for your model) Ground - Brown Unfused wires - a solid red wire is always live - a solid green wire is live in positions II and III - a solid violet wire is live in positions I, II and III Fused wires - a red wire with a stripe of any colour, is always live - a green wire with a stripe of any colour is live in positions II and III - a violet wire with a stripe of any colour is live in positions I, II and III
X3 F25 LCI 30d M Sport
Alpina Roadster S |
09-01-2016, 02:21 PM | #6 |
Rep 66
Thanks for the replies all...
I really need to run everything from the fuse box if at all possible. Im going to try the OBD port tomorrow. Thanks for the wiring info Perrygunn.....I will look at that tomorrow when trying the OBD port! |
09-05-2016, 05:59 PM | #7 | |
Rep 2
thanks |
