      08-25-2016, 11:06 AM   #1
tweaf
Drives: 2013 X3
Rear suspension bushes
Hi,
Just had four new tyres fitted and tracked - advised that D/S rear bushes are worn - not tracking properly - only 56,000km - 2013 1.8d X3.
Seems verye arly for this to happen, hasn't been overloaded etc., anyone else experience this?
Thanks
      08-25-2016, 11:25 AM   #2
Tjalle
Drives: X4 35i
It has been said on this forum, that you have shitty roads in Ireland, but it still seem to be early.
Do you notice anything? Handling? Tyre wear?
There has been incidents where dealers/shops are pushing for unnecessary work
      08-26-2016, 04:27 AM   #3
tweaf
Drives: 2013 X3
Trusted indy, no issue. Suburban roads albeit with ramps but still three times the mileage on my car and not a problem.
Strange..
      08-26-2016, 09:09 AM   #4
epiphone3
Drives: 2013 BMW X3 35i
Any symptoms of this issue in how the vehicle drives? Did you have them replaced? Does the vehicle drive different after replacement?
I will say that the front thrust rod bushings on my X3 were found to be cracked at my last service, around 75,000 km.
      08-27-2016, 06:11 AM   #5
tweaf
Drives: 2013 X3
No drives as normal, but want to get it fixed as don't want excessive tyre wear etc.
