08-29-2013, 10:01 AM | #1 |
Rep 56
Mileage on oem Goodyear ls2's
I have a 2012 BMW x3 with about
13,000 miles to me it looks like I am Going to need tires soon. Can anyone Else tell me the mileage they are getting |
08-29-2013, 10:09 AM | #2 |
Rep 1,560
14,500 and mine need replaced now.
08-30-2013, 09:32 AM | #8 |
Rep 73
About 20k miles on my LS2. Outside wear on two front tires, had them rotated. Will need new tires in next 5k miles or so. Not happy. Also not sure what to go with next.
08-30-2013, 12:49 PM | #9 |
Rep 876
we got 31k miles on out 2011 LS2s. Dealer said that was some of the highest mileage they've seen on them. I drove them hard too. Replaced with the new potenze rfts.
08-30-2013, 01:42 PM | #10 |
Rep 56
My tread is ok in the center and inside it is the fronts on the outside
I would assume this had the quicker tire wear based on my driving habits! Lesson learned I guess |
08-31-2013, 09:47 AM | #12 |
Rep 85
Drives: 2022 X3 M40i
My 2013 X3 has about 12K on them and they are like new. My 2011 528 had about 43K when I changed them and they probably had another 3-4K left. I could have gotten 50k easy on the 528 but was not aware of the factory positive camber on the front of BMW's which caused the excessive wear on the outside edge. I plan to rotate the X3 at 15K to reduce the wear with them. Guess I am one of the luck ones that received two good sets of tires.
09-01-2013, 09:34 AM | #13 |
Rep 181
Apparently run flats get about half the mileage of standard tires and cost twice as much. That makes them 4 times as expensive on a per mile basis, and they don't handle or ride as well either. I'm going with non-run flats when my original tires wear out. Worst case is I'll have to get towed if I get a flat, but you'd have to do that with a run flat anyway if you want to repair and reuse it.
09-01-2013, 03:51 PM | #14 |
Rep 2,323
09-05-2013, 12:44 AM | #16 |
Rep 159
I got 35k outta my LS2's
Frankly, I was surprised. I don't think I've ever gotten 35k on any tires I've run on any car I've owned. Plenty of highway miles on there.
2012 X3 35i | Space Gray | Sand Beige | Sienna
Packages | M-Sport | Cold I & II | Tech | Premium | Sound | BMW Apps, HUD, Net |
