      06-14-2012, 10:40 AM   #1
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
Highway MPG
Just thought I'd share this screen capture... all highway with the cruise set.
Mileage took a dump as soon as I hit the congestion of city streets but neat just the same.
      06-14-2012, 02:08 PM   #2
rmeir
Drives: x3
wow
      06-14-2012, 02:56 PM   #3
BMRu4ia
Drives: 2013 X3 28i VR
In the real world driving, do you think most 35i drivers save more gas than 28i drivers? My theory is that with so much power (35i) on tap, one might not feel the need to put the "pedal to the metal" all the time unlike a 28i driver who might want to squeeze every once of power out of the 4 cylinder turbo.
      06-14-2012, 03:04 PM   #4
April1
Love All
April1's Avatar
Drives: X3 28i 2011
I had touched 35 mpg but with speeds restricted to 65mph. But this average was not including startup and street road driving until hit the freeway.
In short, touching 35 to 38 mpg is feasible with X3 28i or 35i.
      06-14-2012, 05:14 PM   #5
rmeir
Drives: x3
65? how can u drive at 65? i cruise at 80 and it feels like 30
      06-14-2012, 05:22 PM   #6
BMRu4ia
28i or 35i owner?
      06-14-2012, 06:20 PM   #7
April1
Love All
April1's Avatar
Drives: X3 28i 2011
You got to have 65 years of experience to limit the speeds to 65
      06-14-2012, 09:57 PM   #8
Le Chef
Drives: BMW X3 35i
My wife drives at 80 on the highway and gets 20 mpg max. Town driving it's in the low teens.
      06-14-2012, 10:01 PM   #9
DouginNC
DouginNC's Avatar
Drives: 2008 128i Convertible, 2011 X3
I drive pretty easy and I'm averaging about 26 Mostly Hwy. with some city. I don't know how you guys are doing 30 miles per gallon.
      06-15-2012, 06:53 AM   #10
n55x3
Drives: n55 BMWs
I can usually get 28 mpg when I'm doing an early morning cruise to our cabin. This pic was taken on arrival, before I hit the foothills I was pushing 29 mpg. Then the last several miles are all up hill so it dropped to around 27 mpg. Still pretty impressive. I have a tuned Subaru legacy GT that can only dream of getting 27 mpg on this exact same drive. Cool stuff BMW!!
      06-15-2012, 07:49 AM   #11
lbjgh
lbjgh's Avatar
BMW has done a great job of economy with our 2 tonne cars... The 8spd is likely a significant contributor with respect to economy.
Interestingly fuel economy is better in ''drive" than in neutral. I was in the habit of bumping the trans into neutral on long down hills or costing up to intersections in my last car. I've noticed with the BMW that in neutral the real time monitor indicates 1.7L/100km but when the car is left in "D" the monitor will often note "0" L/100km
      06-15-2012, 09:21 AM   #12
lukeeesteve
Drives: A hertz rental car
When you put a modern day car in neutral, the engine still runs as fuel goes into the cylinders to keep the engine running. If you leave it in drive, no fuel is burnt as the wheels at this point drives the engine.
      06-15-2012, 10:24 AM   #13
snowboardjoe
Drives: 2013 X3 28i
I would say any reading while the car is in neutral would be unreliable. That's not driving. Neutral is only be used for special situations where you need the car to roll with the ignition on. Regardless, the engine is always burning fuel if it's running (drive, neutral, park, etc.).Just because you're going downhill does not mean that the fuel is cutoff. It's still burning fuel, but at a very, very low rate.
In my opinion, shifting into neutral while driving creates an unsafe condition. Brakes, power steering and other functions depend on the engine running at a speed above idle under normal driving conditions. Running the car in neutral while coming down a hill at speed puts the car (and you) at a disadvantage. I have a friend that does this and it drives me insane. No fuel is saved by this practice.
Joe Morris
      06-15-2012, 10:56 AM   #14
lbjgh
lbjgh's Avatar
The steering and brakes work just fine in neutral.
In the 'great white north' and before ABS and stability control, using neutral saved my bacon several times especially in icy conditions.
I think I read a post by Lotus7 that said the motor would stop injecting fuel on deceleration and the motor just becomes a big air pump.
      06-15-2012, 01:20 PM   #15
Patton
Drives: Q5
Diesel
After 30 mls on cruise control set on 70 my display reeds 48,3 mpg
      06-15-2012, 01:26 PM   #16
n55x3
Drives: n55 BMWs
Power Steering isn't effected by engine RPMs on this car as it's a 100% electrical unit.
Got me thinking though, I wonder if the Brake Energy Regen works when in neutral? Does the little meter at the bottom of the speedo go into the Blue section when in neutral and rolling?
      06-15-2012, 02:42 PM   #17
lukeeesteve
http://www.popularmechanics.com/_mob...?click=main_sr
If you don't want to read the whole article,
"Almost all vehicles show a pulse width of zero when coasting while in gear. Zero, as in there is no fuel injected at all. Yes, the engine is turning over, the pistons are going up and down, the water pump, alternator and a/c compressor are working, so technically you can say the engine is running, sort of. But it's not consuming any fuel. And that goes for automatic or manuals. "
Regardless, It's always good practice to leave a car in gear. Having power instantaneously available is always safer.
      06-15-2012, 03:00 PM   #18
lbjgh
lbjgh's Avatar
If I recall correctly the efficiency meter is not displayed in neutral.
      06-15-2012, 03:38 PM   #19
Polar_Bimmer
Drives: 2011 BMW X3 (F25) xDrive 28i
Remember, Canada = imperial mpg, USA = US mpg
Imperial gallon = 160 oz or 4.5 liters
U.S. gallon = 128 oz = 3.8 liters
As the imperial gallon contains more, we go further with our gallons. Which seems to give a better gas mileage on the computer.
In Canada we generally calculate fuel consumption in liters per 100 km (l/100km)
1 km = 0.6 miles
      06-15-2012, 07:20 PM   #20
lbjgh
lbjgh's Avatar
Frank,
Lessons for our american friends?
It is a good point though... But I believe mpg are displayed in US gallons since we use SI measurements.
I did take a picture in L/100km too so I can tell you shortly if mpg is imperial or US.
      06-15-2012, 08:33 PM   #21
lbjgh
lbjgh's Avatar
The car displays US mpg
1 km = 0.6 miles
      06-15-2012, 09:20 PM   #22
02420X3
Drives: 2011 X3 35i
33.1 US MPG is certainly respectable for a non-diesel. The best that I have legitimately achieved so far is 29.2, but that was with a slightly heavy foot, and over a 150 mile distance. And then there was that Lexus that annoyed me for a few miles...
I can play with the system and make it show false readings of 40 or 60 MPG or more, but it's not sustainable, and is best achieved downhill immediately after a reset.
