      12-03-2014, 01:19 PM   #1
sunnyw979
Drives: '07 E83 X3 3.0si
Question transmission fluid flush. to do or not to do?
I own a '07 3.0si AT, 103K. Im aware that BMW claim that the transmission fluid in these models are "life time". But realistically more than likely isn't. So I was wondering whether if anyone has done a transmission flush and notice any changes.
TIA
      12-30-2016, 02:55 AM   #2
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Do it for sure, just choose correct fluid.
      01-17-2017, 04:47 PM   #3
humbertob
humbertob's Avatar
Drives: '16 BMW M235i
Just did mine with 70K, no problem at all ! Really Straigh ! Just use the correct fluid and trans oil filter !
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i
'19 G01 X3 | Wife's
'15 F30 335i M-Sport | Son's
'10 Porsche Boxster
      02-14-2017, 03:46 PM   #4
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Yes I would flush had 100,000 miles
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      03-03-2017, 04:39 PM   #5
doru
doru's Avatar
Drives: e92, f25, e46, e83
Just changed the ATF fluid, filter, transfer case fluid, front & rear differential fluid.
For ATF you have to observe the correct fluid level - tranny needs to be at 50°C after the first fill, then fill up until it starts to trickle (overflow). Once it's done, one would reset transmission adaptation values & go to through the re-learn process of the tranny as per TIS. For TC you also need to re-program the TC with Rheingold or similar.
Stable:
e92is
f25 N52
e83 N52
e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30)
      08-21-2018, 02:19 AM   #6
Belginique
Drives: 2007 e83 30SD
Hi All,
Quick question, is there an easy way to read the transmission temperature without a PC? I am planning on a transmission oil change on mine and I am really struggling to get Easy DIS to work on my Win7 machine... it is like it was designed to be hard to install.
Thanks,
Dan
