11-10-2020, 09:56 PM | #1 |
Rep 32
Software Update Problem - Car won't turn on of off
Hi Everyone,
So I'm stump and a bit in panic mode. I was in the process of recoding my RDC (replaced module for TPMS) and doing a complete software update. Everything was going smoothly until certain unit was not able to update (failed). ISTA+ asked my to turn ignition off and put in driver seat belt but I can't turn of the ignition at all. The ignition button isn't working. That's when I realized I was in trouble. - Currently the car ignition is on (car off) - Power supply is attached to car. - Genuine BMW ICOM is connect to laptop and car. - I wants to rerun the update but ISTA is telling me to turn of "Terminal 15" and wait 10 sec and turn it back on. Terminal 15 is ignition?? hmmm.. Should I disconnect the battery and cross my fingers that the ignition button work. If it doesn't turn on I wont be able to redo the update on ISTA Update: Disconnected the battery. Now the car won't turn on at all. Yikes... I might just have to tow the car Last edited by one9kilo; 11-10-2020 at 11:41 PM.. Reason: Update |
11-11-2020, 11:51 AM | #3 |
Rep 2,547
I'd ask in the BMW Coding and Programming forum for help.
Is this your first time programing modules? Which module failed to update? |
dtox9336.00 |
11-11-2020, 02:29 PM | #4 |
Rep 32
Quick update..
So after disconnecting the battery the ignition won't turn on at all (not surprised) but I had to do it. Because the ignition can't turn on, the ISTA won't interface with the car. Pretty much screwed at this moment. pungo From what I remember CAS failed the update but I don't remember what the others were and there were definitely others. According to the fault tree, my DME and EPKG is RED (no communication with those). Yes, this is my first time programming. All I really wanted to do was code the new RDC (which succeeded). Didn't realized that ISTA was going to do a software update automatically. |
11-11-2020, 02:58 PM | #5 |
Rep 32
Basically I was trying to see if there is a way to interface with the car without the ignition on but most likely not. SUCKS!
I'm probably just going to get it towed to the dealership. Anticipating a big bill... Not sure what went wrong. |
11-11-2020, 08:04 PM | #7 | |
Rep 77
11-11-2020, 08:13 PM | #8 | ||
Rep 232
11-11-2020, 09:44 PM | #9 |
Rep 2,547
11-11-2020, 09:48 PM | #10 |
Rep 232
11-11-2020, 09:59 PM | #11 | |
Rep 2,547
Have you looked at the ista log files? They may at least show what things went wrong. \EC-APPS\ISTA\Logs\ I've been wanting to update all applicable modules since I have an early 2011 build with original as built versions and there's some missing features, but I'm concerned something may go wrong. Besides I don't have an icom so would need to use esys which may be even riskier. |
11-12-2020, 01:26 AM | #12 | |
Rep 32
I will take a look at the logs. Yea.. I was sitting there trying to come up with an alternatives but honestly I had to send it to the dealership. I don't have Esys either. Even if I did, I can't communicate with the car. I could roll the dice and replace the CAS myself but that's seem to be digging a bigger hole.
ISTA updated software when I "execute measured plan" in attempt to just code the RDC. Was there a way on ISTA to code just the RDC alone apart from other modules? To be fair, I anticipated that ISTA will do that but I didn't think something would go wrong. Battery was good. I had a power supply hooked up and a genuine ICOM connected. I even sat in the car afraid to open the door to get out during the update LOL. I did try to roll down the window during the process tho... that can't be it can it???? Whatever. It's life. Car is currently are the dealership but won't be checked up until tomorrow. As with whether you should update your vehicle. I say hold off until you REALLY need to lol. What pisses me off is that I really didn't need to! Anyways, thanks all. Quote:
11-15-2020, 04:19 PM | #13 |
Rep 32
Update:
Dealership fixed the issue. They did what I expected them to do - Reset CAS module, remove corrupt software and then update everything. I expect it only took them less than an hour to do; although, I paid for 2 hours of "work." I'm pretty sure some of the tech geniuses on here would be able to do the same. I don't have the knowledge base to tackle the issue myself. Plus, I don't have an other program beside ISTA+. Total cost was $470. Here is the interesting part. They tried to charge me $750 and blamed it on computer issue for the price error. The guy stated that the computer automatically prints out the price which I think is BS since the hours and rates wasn't even inputted. Anyways. All is good. |
11-15-2020, 04:34 PM | #14 |
Rep 253
I tried to replace my battery myself and the car was very sick with the new battery. Struggle to get it to crank, then it would refuse to start. Worried I messed up a computer. Old battery back in, it worked fine.
Never got the car in good enough shape to reprogram the car to the new battery. Like you, not enough tools and this type of experience to fix myself. |
11-15-2020, 05:20 PM | #15 | |
Rep 32
11-15-2020, 06:22 PM | #16 | |
Rep 2,547
Setting the correct capacity and registering is a must once the new battery is installed and working to get the best life from the new battery, but in your case you didn't get that far. |
11-15-2020, 07:39 PM | #17 | |
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
11-16-2020, 04:54 PM | #18 |
Rep 253
It was tested when I returned it to the store, and tested good. And the cranking was energetic. Odd. Saw a post on the interwebs after I returned it that suggested unplugging the battery for 10 or so minutes and trying again. But by that time the battery had been returned.
I went this route since the closest dealership was quoting $525. I ended up getting it done for $260 or so at another dealership which if I had known was that cheap I would have just gone that route to begin with. |
11-16-2020, 05:18 PM | #19 | |
Rep 2,547
