11-09-2020, 08:44 PM | #1 |
Rep 157
Drives: 2007 328i e90 - 2015 X3 F25
2015 Transfer case leak
After my usual oil change maintenance done at my BMW "stealership", service advisor mentioned that they noticed a transfer case fluid leak that needs attention. Diagnostic checkup cost $189 (Canadian)/hour. Actual labour for the repair + materials are additional. I opted out and told the guy I'll check w/ 3rd party BMW repair shop for quotation.
Based on the attached photos, how worried should I be? Is it something that needed fixed right away? Could it be the gasket, rubber ring, or whatever? How expensive is it to get stuff like this fixed on a 2015 F25? Tnx for your input.
My other BMW.
11-09-2020, 09:57 PM | #2 |
Rep 1,044
If you are going to keep the car, I would get it fixed. Gasket or seal.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
11-09-2020, 10:41 PM | #3 |
Rep 157
I eventually might end up getting the dealer fix it. My extended warranty which would've covered this repair expired June, 2020. I'm planning to keep the car so peace of mind is a necessity.
My other BMW.
11-10-2020, 06:58 AM | #4 |
Rep 195
Drives: BMW,Tesla, etc.
It has to be fixed asap. Estimated cost around $1K USD since t-case has to be dropped.
11-10-2020, 04:55 PM | #6 |
Rep 2,547
I agree to fix the leak asap, it doesn't hold much fluid and could cause serious damage if driven when too low.
