10-26-2020, 11:35 AM | #1 |
Rep 38
Bilstein Shocks , where can I find front strut mount ?
Hello,
This is for 2013 BMW X3 35 I I have front bilstein shocks but my mechanic told me you need a complete strut assembly and then he told me he can used the same spring or coil. So what else do I need ? Only strut mounts ? Can any strut mount fit with Bilstein BMW X3 35i or is there any specific strut mount for bilstein shocks Pictures attached for what I have ! |
10-26-2020, 12:48 PM | #2 |
Rep 615
There's only 3 wear parts besides what you have in the picture. Those would be the bump stop, bellow and strut mount. So technically you could transfer over your OE parts and you're done. However that doesn't mean your bump stop or strut mount are in good condition. If you don't know the condition of these items then you may want to replace them all.
10-26-2020, 06:05 PM | #3 |
X3 Newbie
12
Rep 27
I just installed new bilstein b4 front struts on my '11 x3 28i, exact same struts as the ones in your pic (same part numbers). I only replaced the struts and strut mounts. ordered them from autohausaz.com since i'm on west coast.
fcpeuro makes a nice front strut mount kit if which inlcudes everything you need: https://www.fcpeuro.com/products/bmw...-31306852158kt I reused my bump stop since they were in acceptable condition, not torn, but new would of been nicer. But you will need to get the new screws because they are self tapping and should only be onetime use. I freaked out when I first saw my new mounts were not threaded, they are oem Lemfoerder. had to research to verify the mounts do not come threaded and should use mounting screws only once. I ended up reusing the old ones becuase I didnt want to wait 3-4 days to get them and of course I did the struts on a Friday and woulda had to wait til wednesday-thursday, even the dealer had to order these. I'm doing the rears in near future and will be replacing bump stops as well since they're torn.
2011 X3 xdrive28i w/158K miles - New Baby
2004 325ic 215K miles - SOLD 2002 325i 230K miles - GAVE AWAY to Family, Still Runs |
10-26-2020, 06:35 PM | #4 |
X3 Newbie
12
Rep 27
Sorry for the long response, the short answer is yes, you need the specific strut mount for your year/model, which are the ones listed in link, and you will also need the new self-tapping screws.
Inspect the struts and if the bump stops & protective boot sleeve are not torn, you can reuse them. If they are torn, i would advise to get new ones to protect the new shocks from premature wear.
10-26-2020, 06:54 PM | #5 |
Rep 2,547
I'd recommend getting the complete strut installation kit with new bump stops. The bump stops are an integral part of the suspension characteristics and can become stiff over time and could even crack and fail. I've seen where the bump stop cracked and the dust boot falls onto the top of the strut and caused it to rust.
10-27-2020, 09:42 AM | #6 | |
Rep 3,548
I used to just swap struts, then started doing more parts, then finally realized after a few decades that doing the whole combo was usually best. |
10-29-2020, 09:19 PM | #7 | ||
Rep 38
I wish I could have watched your link , I just ordered it in morning. So this is what I order for strut mount , but I am not sure why your product Id is different than mine. For other stuff I will contact bmw here to get it , now I got an idea what to order like bolts, bump stops etc. Thanks man really appreciatef https://www.carid.com/lemfoerder/fro...24553-lem.html |
10-29-2020, 09:58 PM | #8 | |
Rep 2,547
10-30-2020, 02:59 AM | #9 |
X3 Newbie
12
Rep 27
Agreed, if you are able to return without too much of a loss, perhaps just shipping cost, might be worth it. The front oem Lemfoerder strut mounts usually go for around $30-$32/each at a few sites, unless the $52 is for both mounts, seems high for just one mount.
10-30-2020, 04:40 PM | #10 |
Rep 80
You should replace the springs at the same time as its no extra labour. You will need an alignment. If replacing the springs wait a few days for the alignment.
