      07-26-2018, 10:12 AM   #1
rockit2
rockit2's Avatar
16
Drives: 2011 F25 N55
f25 offset
looking at upgrading the stock 18's they have corrosion forming around the lug holes and had a question. Which would push the wheel to the outside more
19x8.5 front 35 offset
19x9.5 rear 40 offset
OR
19x8.5 35 offset all the way around
the stock wheels look very tucked in wanted a wider stance
      07-26-2018, 10:23 AM   #2
E90705
E90705's Avatar
Drives: E90/F25 M-sport
OR
You can add wheel spacers. Depends if you want a staggered wheels/ tire setup.
      07-26-2018, 11:05 AM   #3
rockit2
rockit2's Avatar
16
I found a set of oem x3 19" front are 19x8.5 with 46 offset and the rear are 19x9 with 51 offset for the yspoke wheels so do these tuck in more compared to the 35 offset stick out more
      07-26-2018, 05:14 PM   #4
BIG_KID
BIG_KID's Avatar
68
Drives: 2011 X3 28i
Lower number ET (offset) means the wheel will stick out further
      07-26-2018, 07:15 PM   #5
Victoracer
Victoracer's Avatar
Drives: F25 X3 xdrive35i M-Sport FBO
https://www.willtheyfit.com/index.ph...9-5&offset2=22
      07-27-2018, 09:14 PM   #6
WagonR
Drives: 2017 M2
The factory 18s appear to be 18x8 with a 43mm offset. That means the face of the wheel would be 58.5mm (2.3 inches) from the hub (203mm width, divide by 2 to get the 101.5mm midpoint, less 43mm of offset = 58.5mm hub to face of wheel).
For the wheels you show
19x8.5 35 offset = 73mm (2.9 inches) from hub to face of the wheel (216mm width/2 = 108mm midpoint - 35mm offset = 73mm)
19x9.5 40 offset = 80.5mm (3.2 inches) from hub to face of the wheel (241mm width/2 = 120.5 - 40mm offset = 80.5mm)
In summary -
19x8.5 35 offset will stick out 14.5mm (0.6 inches) further than stock wheels
19x9.5 40 offset will stick out 22mm (0.9 inches) further than the stock wheels
Current:
2017 F87 M2 6MT
2013 F25 X3 3.5i
2008 E90 M3 6MT
      07-28-2018, 10:46 AM   #7
Taoster
Drives: F25 n20
Wheel spacers
