      09-28-2017, 09:00 PM   #1
batlin
batlin's Avatar
43
Drives: BMW X5
Charge Pipe replacement DIY?
I searched and couldn't find anyone on here that has done a Charge Pipe for the X3 by themselves. Looks like on other BMWs it is fairly easy but wanted to confirm it is easy on the X3 before I order the part.
Thank!
      09-29-2017, 10:47 PM   #2
Nerdking
Drives: 2021 530i
Hey! I just had the charge pipe on my 35i fixed at the dealer under warranty after it burst under WOT.
Apparently it's not so easy on this car. I'll post the info from the invoice below.
"Removed belly pan, air filter housing, Air intake tube, drive belt, and separated air conditioning compressor. Removed and replaced charge air pipe between intercooler and throttle body."
Sounds like a lot of work.
      09-29-2017, 10:54 PM   #3
batlin
batlin's Avatar
43
Drives: BMW X5
F***.... ok thanks! I think I'll pay the 2 hours of labor Thank you!
      09-30-2017, 08:18 AM   #4
batlin
batlin's Avatar
43
Drives: BMW X5
Do you all think it is safe to drive my car 3 miles to the shop with a blown boost pipe?
      10-01-2017, 10:15 PM   #5
Nerdking
Drives: 2021 530i
I think it will be fine if it's just 3 miles, can't be sure though.
      10-02-2017, 06:44 AM   #6
ina93
Isa Ali
ina93's Avatar
Trinidad_and_tobago
12
Drives: 2012 X3 35i
It’ll be fine don’t worry, I had to drive 20 miles to my dealer when mines got broken.
Polo088161610.00
      10-02-2017, 08:56 AM   #7
batlin
batlin's Avatar
43
Drives: BMW X5
THank you! I took a look and found the gasket just sitting at the opening of the throttle so I pulled that out so it didn't get sucked in
      11-13-2017, 08:02 PM   #8
ThomasR
Drives: 22 X3 M40i
Thank!
I changed mine this past weekend. I upgraded from stock to aftermarket aluminum. At first I thought it might be impossible but I kept working at and it wasn't bad at all. You have to come out of the top though. You don't need to remove the compressor. I removed the intercooler and the airbox. The aftermarket was a split design (as stock should have been) and it was very easy to install. It will be so easy to remove as well if I ever need to.
      11-14-2017, 12:49 PM   #9
E90705
E90705's Avatar
Drives: E90/F25 M-sport
Thank!
I replaced mine with FTP ones. Black aluminum charge and boost pipes..
It's relatively simple bolt on process.
I changed just in case the stock CP decides to blow.
      11-14-2017, 01:11 PM   #10
E90705
E90705's Avatar
http://x3.xbimmers.com/forums/showth...ht=Charge+pipe
Thank!
      11-14-2017, 01:24 PM   #11
E90705
E90705's Avatar
Thank!
https://www.ebay.com/itm/FTP-Charge-...5Y2Hj6&vxp=mtr
I used the FTP kit. it bolted right up. good replacement since not many companies make CP for our n55 F25 x3's
      01-30-2018, 10:24 AM   #12
Nick74
Drives: X3_28ixdrive
do you guys know where I can get a cold air intake for my 2013 28i?
      09-10-2018, 05:21 PM   #13
Mbaylis
Drives: 2014 BMW X3 xDrive35i M-Sport
FTP Kit or just FTP Charge pipe?
Do I need both for an MHD Stage 1 tune or just the charge pipe?
This one?
or this one?
https://www.ebay.com/itm/BAR-Autotec...MAAOSwhQhY2H7g
Trying to save some cash if it's not needed.
      09-10-2018, 07:19 PM   #14
E90705
E90705's Avatar
This one?
https://www.ebay.com/itm/FTP-Charge-...j6&vxp=mtr
or this one?
Sir, just the charge pipe side is the necessary one, however I went ahead and did the boost pipe also.
Simple process just can be tricky getting stuff out of tight spaces.
      09-10-2018, 07:29 PM   #15
Mbaylis
This one?
or this one?
This one?
or this one?
Thank you!
      09-10-2018, 07:31 PM   #16
E90705
E90705's Avatar
Charge pipe 1st pic vs stock one
Charge pipe installed in 2nd pic
Last is boost pipe compared to stock.
      09-12-2018, 07:59 AM   #17
Bufalo
Drives: 2009 328i
2017 BMW X3 35i  [0.00]
2009 BMW 328i  [0.00]
I like that those are painted black, don't need a lot of extra bright metal down in the depths of my wife's car. Aside from the longevity, have you noticed any other direct benefit from having the solid pipes?
      09-12-2018, 10:08 AM   #18
TheCoolX3
Drives: 2016 BMW X3 35i M-Sport
I did this a few months back. If you were on the edge of buying, I would definitely do it and go for the FTP kit. The added peace of mind that your charge pipe wont explode at WOT is pleasing.
Theoretically there wont be much of a difference in the feel of the car because you're just replacing pipes. I do feel like throttle response and the boost noise is a bit better but that very well could just be placebo.
The 'better' throttle response could be from the lack of ridges and bumps in the solid pipes that the stock pipes have in the flex part, or again, just placebo.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others
Instagram @TheCoolX3
      09-12-2018, 04:27 PM   #19
Riick
There will be zero change in performance, it's just a mod for reliability.
      09-12-2018, 08:47 PM   #20
Bufalo
Drives: 2009 328i
On some older turbo cars, solid intercooler pipes could improve throttle response simply because they didn't blow up like balloons when boost came on!
      09-13-2018, 12:19 PM   #21
E90705
E90705's Avatar
The boost pipe/outlet pipe does appear to allow better air flow as the stock rubber was pretty thin as I imagine it may balloon under wot/load.
My guess ftp pipe =2.5 inch vs oem 2-2.25?
      09-13-2018, 12:27 PM   #22
Merlin82
Drives: 2011 BMW X3 Xdrive35i
I did mine a few weeks back and it wasnt too bad. As others have said, i removed the intercooler and air box, and then it was just a bunch of twisting, pulling and wiggling to get it out. The FTP stuff is much nicer, although i will say their instructions werent a ton of help. Step 4 i think was basically "Put everything back together and your finished". But great quality product.
