      10-27-2013, 03:26 PM   #1
X3Bimmer
Drives: '13 X3 35i - %E2%80%9821 X3 M4
Clear coat peeling off wheels on '13 X3!
Anyone else had this issue on a 1 year old X3? Would this be a warranty issue?
      10-27-2013, 03:34 PM   #2
Cropwell
Drives: 330d msport xdrive
Yes had exactly the same problem after 11 months. Took it back to dealer and all 4 wheels replaced under warranty.
      10-27-2013, 04:04 PM   #3
guyver626
Drives: 2014 35i m-sport carbon black
They replaced all 4 wheels if only one wheel had the problem?
      10-28-2013, 10:58 PM   #4
npcars
npcars's Avatar
Drives: M4Cx / X3 M40i
Do you have a picture of your peeling wheels? I'm curious as to what this looks like. I might have that happening to mine...
      10-29-2013, 02:13 AM   #5
skansa
Drives: Datsun Sunny
npcars can you post a pic of yours?
      10-29-2013, 06:21 PM   #6
X3Bimmer
Here is a picture...
      10-30-2013, 06:38 AM   #7
Edge2112
Drives: 2014 X3 28i
I had tHis with a Toyota a couple of years ago. They kept replacing the wheels, unless/until they were rim damaged. In which case they were yours forever.
Be careful with those kerbs.
      11-04-2013, 10:23 PM   #8
npcars
npcars's Avatar
Yeah, I have that :/
      11-05-2013, 04:23 PM   #9
DonC
Drives: 2013 X3 3.5i M sport, etc
Take it back...
2013 X3 3.5i AW,Msprt,rear fogs,PS,CP, Tech, etc...
Other cars
2005 S2000
2018 i3S
      04-16-2014, 04:53 PM   #10
X3Bimmer
Anyone else aware of this happening? I take it in on Fri but just curious, it looks like they may have them 'repaired' since I have a wheel/tire extended warranty but shouldn't BMW be able to replace them under their original new vehicle warranty provided by them? Any advice...
      04-30-2015, 08:34 AM   #11
X3Bimmer
Is this a know issue to BMW? Maybe an SIB?
      05-11-2015, 01:14 PM   #12
X3Bimmer
I need some input from anyone that has had BMW wheels replaced under warranty. I'm being told that the Service Mgr has contacted BMW since alloy wheels are not normally covered under warranty. They have been "repaired" once already.
      05-11-2015, 02:15 PM   #13
Tjalle
Drives: X4 35i
ALL components, except e.g. windshield wiper blades are covered by warranty. That does include alloy rims - if not damaged.
The peeling is obviously from an incorrect clear coating process - BMW/supplier should replace. They might claim that you have used high pressure hose or aggressive cleaner - don`t buy that.
      05-14-2015, 08:21 AM   #14
X3Bimmer
Update:
All four alloy wheels will be replaced under factory warranty. Awaiting their arrival...
      07-30-2015, 09:19 AM   #15
X3Bimmer
Last update:
All (4) 308 alloys replaced under warranty. I had new tires installed and 4 wheel alignment performed. Dealer was great to deal with and did all as requested with no charge.
      07-30-2015, 09:22 AM   #16
X3Bimmer
Last update:
