02-26-2023, 02:29 PM | #1 |
Rep 323
How to Get the Most from Your Stock X3's Exhaust
I'm sure other X3 M40i (and X3M) owners have noticed that the exhaust note is quite nice from the outside, and surprisingly loud, but you can barely hear it inside the cabin. This is a natural consequence of all the insulation in modern luxury cars. Meanwhile the electronic simulacra BMWs pumps through the speakers is not an adequate replacement for real exhaust noise. Here are the steps I use to get let the most sound inside my X3 with no modifications:
1. Use Sport Plus mode. Just need to press the sport button in the center console two times. As we know this opens a valve in the muffler for more volume and a much sportier tone. I don't think there's a difference in tone between sport and sport plus, but might as well use the more aggressive one. In the M and M40i this also activates a bit of a burble tune you can hear on downshifts. On earlier X3 M40i years (2018, 2019, maybe 2020?) there are loud pops and bangs produced by high-rpm downshifts. These crackles can be quite raucous so use some discretion. 2. Depress the center of the pano roof switch to tilt the glass. This gives more exhaust note inside and far less wind noise than sliding the glass back. Makes a huge difference to sound so I do this pretty much every time I go into sport or sport plus mode. (Remember to close it when you park! It's easy to forget if you don't use it often.) 3. Crack all four windows about an inch. Fully opening the windows sounds fine at lower speeds but any exhaust noise gets overwhelmed by wind rushing/buffeting over about 40 mph. SUVs naturally have to push a lot more air out of the way than cars so it's hard to drive with the windows fully down. At much higher speeds I do close the windows fully because even a slight gap introduces a lot of wind noise. 4. Fold down the rear seats. This one isn't as obvious of a benefit but definitely makes a difference. I'm sure everyone knows how to do this but you press the buttons on the sides of the rear seat headrests to collapse them then pull the releases either at the top of the seat backs or on either side of the trunk. I first noticed the change while driving around with my bike in the car. It's similar to, if less extreme than, how dropping the rear seats in many coupes/sedans can give you significantly more exhaust noise. 5. Push the shifter left to "DS" then pull one of the paddles to lock the transmission into manual mode. Without shifting the transmission yourself you're really not getting the most of any vehicle's exhaust. You can also push/pull the shifter itself but the paddles are far more ergonomic. There are a couple benefits to manual mode over even Sport Plus auto: You can rev out the engine without going full throttle, and you can downshift to near redline. The transmission will not give you the next gear if it's not within the rev limit of the engine so feel free to pull the downshift paddle as many times as you want while decelerating. The closer you redline you downshift the more burbles/pops you get. I find manual mode also gives the most satisfying upshifts under throttle than auto. Also after accelerating if you pull the paddle just before letting off the gas and I think this produces and extra loud upshift burp. Be aware that the transmission will not auto upshift in this mode. You have to shift yourself or it will slam into the rev limiter! If you're not used to using the paddles then maybe try just driving around town in manual mode to get used to them before trying some more spirited driving. You'll also have the benefit of a much more connected driving experience by doing all the shifting yourself. (If anyone is in my area I would be more than happy to provide a demonstration. I suspect many X3 owners are not aware of the performance capabilities of their own vehicle.) Let me know if this works for anyone else and please feel free to chime in with any other tips to get the most driving enjoyment from your X3. |
02-26-2023, 03:02 PM | #3 |
Rep 276
Dumb question, but the exhaust valve fuse is removed , would that equate to a louder exhaust even in comfort mode? I want a slightly louder exhaust tone (can’t do certain stuff since I’m still under warranty)
02-26-2023, 04:33 PM | #4 | |
Rep 323
Also I find that there can be a little bit of drone at a certain RPM and load with the valve open so I like to close it sometimes. |
02-26-2023, 04:35 PM | #5 |
Rep 323
Yeah, if the valve is always open the exhaust will be louder in comfort mode too. I don't think that would make it do the burbles in comfort mode though; would still have to go to Sport or Sport Plus for that.
02-26-2023, 04:37 PM | #6 |
Rep 276
Gotcha. Thank you! And yea I just want a louder exhaust . Gotta wait til my warranty ends in a couple years to add downpipe and tune lol
02-26-2023, 07:27 PM | #7 |
Rep 1,790
Drives: 2022 X3 M40i
Lmao....open windows a touch...and if you want it louder, stick your whole head outside the window.
This thread...wtf. |
10
Rottweiler4021.00 stroberaver42.00 wdeerfield2748.00 foreskin100.50 IAmSpeed1186.50 Tangsta29.00 codeyf119.50 Oldgixxer1932.00 CrownRoyal79284.00 borderwave245.50 |
02-26-2023, 07:31 PM | #8 |
Rep 1,790
Step 1... use any finger on your good hand.
Step 2....take said finger and gently tap switch to corresponding window you wish to open. Step 3... take said finger and jam into eyes...so the body will compensate and hopefully your hearing will improve from the lack of sight and exhaust = louder. |
02-26-2023, 07:42 PM | #9 |
Rep 1,529
An Easter egg is setting the sound to sporty, it automatically opens up the exhaust valve, meaning it actually does something other than piping in fake sound.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
02-26-2023, 08:07 PM | #10 |
Rep 315
Drives: '19 BMW X3 M40
Ok… I’ve had one glass of wine too many but I’m still one eyebrow up on this one.Will read again in the AM.
@enthusiast_1_ Current: 2019 X3 M40x Dark Graphite Metallic; Previous: 2017 BMW M240i xdrive (Sapphire Black); 2013 BMW 335ix M sport coupe (White) beast of a car/let slip away; and 2011 BMW 328ix- coupe (Silver)
02-26-2023, 08:20 PM | #11 |
Rep 323
I just tested this and the exhaust doesn't doesn't seem any louder from sticking my whole head out the window. I can hear the turbo a little better though.
02-26-2023, 09:17 PM | #12 | |
Captain (Retired)
4021
Rep 1,761
Sending your ECU off to Bucharest to get unlocked is extreme I agree, but look at piggyback tunes like the JB4. Re exhaust, an AA catted downpipe is a great start and is not expected to throw a CEL. I went a tad overboard when I did the Stone cat back exhaust, but I’ve had ZERO REGRETS since I installed it. Car sounds amazing! The “to mod or not to mod while under warranty” can be summed up in the video below, with the devil being a fellow forum member here who has led me far astray https://youtu.be/l6PYi0hU7Ng |
02-26-2023, 09:35 PM | #13 |
Rep 472
I can’t believe you wrote out all that nonsense
02-26-2023, 10:01 PM | #14 |
Captain (Retired)
4021
Rep 1,761
02-26-2023, 10:11 PM | #15 |
Rep 1,790
Rottweiler4021.00 |
02-27-2023, 12:26 AM | #16 |
Snr Field Engineer 👮🏾*♂️
215
Rep 257
Just like most of the posters here, I felt like these things were already well known by most of us here and I wanted to comment as well to the OP by saying “Really? A thread for such basic stuff?”, but I thought maybe many new owners will benefit from these steps he tried so hard to put together. I mean there is a reason why toolbox manuals have simple instructions like clean the screwdrivers, ratchets, sockets and store in a safe place after use. It’s not like we don’t know we should be doing that to prolong our tool’s life. It’s more like a reminder.
In the end this thread “wasn’t written for me” and maybe some other posters could refrain from mockery. I mean no one forced you to read the thread, and if you did read it “by mistake”, no one asked your opinion to comment or to tell us how you feel thus making us read your rubbish feelings as well. Now if you wish to write your own thread about exhausts notes and mods feel free to do so rather than hijacking another person’s thread to discuss your personal aftermarket exhaust mod after mocking them for posting a thread about OEM exhaust. Good thread, bad thread, simple thread, plain comments, positive thoughts etc are all welcomed on the forum, bullies stay away! Also, No one has compelled you to read my comment on this or reply to my comment, so shhhh or feel free to rant on how much this has hurt your feelings again. Your choice.
Current - 2020 G02 X4 M40i, B58 engine, Alpine White.
Current - 2016 Toyota Rav4 D-4D, with BMW 2WW Engine, Blue crush metallic. |
02-27-2023, 02:07 AM | #17 | |
Rep 276
02-27-2023, 02:14 AM | #18 |
Rep 323
02-27-2023, 03:07 AM | #19 | |
Rep 323
I'm happy to have a discussion about how maybe the S58 has worse overall efficiency compared to the S55 because despite basically same bore and stroke it has a lower compression ratio meaning a larger combustion chamber and therefore potentially less complete combustion in low-load situations and if people think that might lead to an early retirement of the engine architecture if euro emissions regulations are further tightened despite recent increases in engine management systems blah blah blah... However, yeah some threads can just be simple, if obvious-seeming, tips. Last edited by Coi; 08-24-2023 at 07:49 PM.. |
DonSylver214.50 |
02-27-2023, 03:11 AM | #20 |
Rep 1,790
Man some people are taking responses on A OPEN PUBLIC FORUM personally. Ok, ok everyone calm down, take a deep breath of fresh air.....Oh wait, refer back to steps 2 and 3 of OP post for help.
02-27-2023, 03:15 AM | #21 |
Rep 323
You definitely shouldn't be reading the forum while driving so I'm not sure if the steps apply.
02-27-2023, 03:19 AM | #22 |
Rep 1,790
Tags |
exhaust, exhaust noise, m40i, noise, sport plus, x3 exhaust, x3 m40i, x3m, x3m exhaust |
