10-19-2018, 12:35 PM | #1 |
Rep 62
well went to lunch today and blew the charge pipe
Driving to get a samich at high rpm I heard a big pop and I was WTF then low power I popped the hood and the pipe going to the what looks like the throttle body on the driver side was blown off.
10-19-2018, 12:47 PM | #2 |
Rep 540
Drives: 2016 BMW X3 35i M-Sport
Happens a lot at WOT or high load high RPM scenarios. Id look into getting the FTP replacement aluminum charge pipes
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
10-19-2018, 12:50 PM | #3 |
Rep 62
yea it was right at red line at top of 3rd gear at first I thought I hit something because it was loud, FTP charge pipe for the N55 F25 is that the one I need?
2011 X3 35i sold
2007 335i sold |
10-19-2018, 01:14 PM | #4 |
Rep 540
10-20-2018, 12:22 PM | #6 |
Rep 62
just ordered the FTP charge pipe and boost pipe since it was $50 more for teh boost pipe I figured it wont hurt to have it also as with my luck I would do the charge pipe and then on the first pull the boost pipe would then blow off so I just ordered it now lol
2011 X3 35i sold
2007 335i sold |
________4160.00 |
10-20-2018, 11:40 PM | #8 |
Rep 4
Drives: 2014 BMW X3 xDrive35i M-Sport
10-21-2018, 10:18 AM | #9 |
Rep 470
Charge pipe is relatively easy and can be done without dropping the intercooler. Boost pipe is much more difficult and might require removing the water pump. I'm saving my boost pipe install for when I get a better intercooler.
10-21-2018, 08:40 PM | #10 |
Rep 540
You do not have to drop the intercooler but its so much easier if you drop it or at least loosen it to allow a little more play and flexibility. Boost pipe was easier than charge pipe IMO. Did not have to remove water pump on my N55.
10-25-2018, 02:18 PM | #11 |
Rep 191
Agreed, neither was too hard but dropping the intercooler is pretty easy and made it much easier. The only part I found interesting was that once installed, it still felt like the connection to the throttle body was loose. But I talked with another person who had done it and they said it was normal. So fired it up and it has been working great. Love not having to worry, and that it has a bung to install a meth nozzle should i ever decide to bite the bullet on that.
10-26-2018, 04:55 PM | #12 |
Rep 540
Its for heat expansion so it will tighten as it warms up. Its normal.
