      12-10-2016, 11:15 PM   #1
amoeba
Drives: E46 330i zhp, F30 335-MSport
Trunk not opening automatically
Got a very small tap on the bumper and had the bumper repainted. Afterwards the trunk doesn't open automatically when pressing the trunk release button.
Before:
- When holding the trunk release button, the door would eject and lift itself up automatically
- After trunk is closed, I usually hear an additional motor sound as if the trunk is getting sucked in, sealing it.
Now:
- When holding the trunk release button, I hear the unlock click, but the door doesn't go up automatically. Seems like it doesn't eject
- If I life the trunk gently just a little bit, the trunk would lift up all the way automatically. As if it's detected it's been ejected.
- When trunk is closed, I don't hear any additional motor sounds sucking the trunk in.
The body shop only touched the bumper to repair it. Is the trunk supposed to be ejected a little bit for the lift arms to take over? Body shop is suggesting my liftarms could be worn but it seems fine going up. I'm just not getting the eject/pulling in effect it seems.
      12-11-2016, 12:40 AM   #2
Tjalle
Drives: X4 35i
Obviously it is the kick up/locking device that does not work.
Either the "tap" or paintshop is responsible.
      12-12-2016, 03:37 AM   #3
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Also possible you suffer from bad software level. My F10 (shares same hardware) would only open a few inches. After dealer updated software, everything was working.
