      12-11-2013, 06:06 PM   #1
RDLear
Drives: 2019 430i XDrive Gran Coupe
2013 BMW X3  [0.00]
Suggestions for Jacks
Just got my new set of winter wheels and tires from TireRack. 18x8 BBS SR Anthracite wheels and 245/50R-18 Michelin Pilot Alpin PA2 ZP (Went with one size smaller than the M Performance 19" wheels for snow/winter driving).
Any suggestions on a good jack for spring and fall swap out use in the garage at home? Also eyeing the Gorilla Extendable Power Wrench - anyone use one? Likes/Dislikes?
Appreciate any experience and thoughts.
      12-11-2013, 06:23 PM   #2
BeeMdblU
BeeMdblU's Avatar
Drives: F86, F25, G16
Costco jack is good enough but you need the puck at the lift point
      12-12-2013, 09:05 AM   #3
n55x3
Drives: n55 BMWs
I've had the 1.5 ton aluminum racing jack from Harbor Freight for about 6 months now nad it does really well lifitng out BMWs. They can be had for around $60 if you time the coupons right:
http://www.harborfreight.com/1-12-To...ODY1NiJ9%0D%0A
I also have their larger 3 ton steel jack and it's a monster. I use that on our bigger vehicles but it's way overkill for X3.
Like Bee mentioned above, be sure to get the jack adapter pad otherwise you'll squash your plastice lift points. I've used a cut off 2x4 in a pinch but the adapter is well worth it.
      12-12-2013, 12:02 PM   #4
guyver626
Drives: 2014 35i m-sport carbon black
If you go to an Indy shop. Should u expect them to have the pucks? Otherwise wouldn't they ruin the jack points? Should i be buying 4 of the pucks?
      12-12-2013, 12:24 PM   #5
n55x3
Drives: n55 BMWs
Indi shop would definitely need the pucks. They probably need 4 if they are using a multipoint lift.
For home use I get by with just one. I can lift a corner and do whatever needs to be done and then move to the next corner. For the oil changes I don't even mess with a jack, I just drive up some small ramps.
