      07-15-2013, 03:23 PM   #1
buze
Owner
Drives: G05 30d M-Sport
Tire Pressure Loss warning on all 4?
This morning, i had that warning on the motorway, with recommendation I drive at less than 60 and check the tires.
I checked the tire (quite honestly, for the first time) and they were over on one side (40ish) and sorta normal on the other (34 ish) ... thats strange, because the recommendation says 30 at the front, and 32 at the back... Anyway I put 33 at the front and 35 at the back, as I prefer a firmer ride...
Anyway, what could explain a warning indicating all FOUR wheels? I hadn't driven the car in 2 days, and it's very very very hot for this country, I've been wondering if that hasn't tripped the sensor somenow...
Received 190911: X5 30d M-Sport:Artic Grey:Comfort Pack:Tech Pack:Visibility Pack: Driver Assist Pro Pack:Heat Pack:Glass Roof:Leather Dash
      07-15-2013, 03:27 PM   #2
Broch
Drives: BMW X3 35d M-Sport
When the tyre sensor alarms, it does not show which corner it is for.
All 4 tyres need to be checked to determine which one it is alarming for.
HTH
X3 35d M-Sport
      07-15-2013, 04:00 PM   #3
brissim
Drives: X3 30d (2011 F25) - now sold
To expand a little on what Broch said, for us in those markets that have the indirect TPMS which uses the cars ABS system to detect a variance in rotation between the tyres as a means to detect a low pressure. This system can't actually detect which tyre has the lower pressure - only that there is a variance. Hence it alarms on all four tyres and then you have to find out which one is low.
First time it happened to me I also assumed the system was playing up. I checked anyway and found one tyre had dropped from the normal 36 psi to 26-27 psi. The system works!!
Tony
      07-15-2013, 06:30 PM   #4
paul386
Drives: 2011 X3 35i Jet Black
This is not true. If you get the software update the fixes (among other things) the transmission stuttering then the low tire screen will show which tire is low.
      07-15-2013, 10:43 PM   #5
brissim
That may be the case in your US market where you use the direct TPMS where you directly measure the tyre's pressure, but is that the same in those markets (which includes the UK and Australia) where we use an indirect TPMS based on the cars ABS system to detect relative variances in rotation?
Tony
      07-15-2013, 10:44 PM   #6
paul386
Prior to this software update my had the same symptoms as you (all 4 tires indicated low). Perhaps there are some differences that I am not aware of though! Worth a shot.
      07-17-2013, 03:02 PM   #7
HighlandPete
Drives: BMW F11 535i Touring
The indirect TPWS (Warning, not Monitoring) as used in the UK, will not indicate a particular wheel as being low. If all four go down together there is no warning. Hence why regular pressure checks are still essential.
HighlandPete
      07-17-2013, 05:11 PM   #8
stumblingtrout
Inspector Gadget
Drives: MY14 X3 35d M
When I picked up a nail in my 530d, it told me exactly which tyre it was... does the X3 not do the same?!
MY14 X3 35d M-Sport. Born 19/04/13, Delivered 31/05/13. Alpine White, Red Brown Leather, Brushed Aluminium, 19" 369 Alloys, BMW Media - Professional, Visibility Package, Access Package, Electric Seats w/ Lumbar, Variable Damper Control, Panoramic Roof, Extended Storage, HUD & Black Panel Dash, DAB, Reversing Camera & Top View, Heated Steering Wheel, Heated Rear Seats, Apps, Internet, BMW Loudspeaker Professional... & More.
      07-17-2013, 05:37 PM   #9
HighlandPete
In the 5-series do you have the optional Tyre Pressure Monitor? Or are you saying the standard TPWS system is now picking up an individual wheel and displaying it on the screen. Orange or red?
I can't see why on the latest cars with visual display, where there is a definite failure on one tyre, the specific wheel shouldn't be identified and displayed.
HighlandPete
      07-18-2013, 07:48 AM   #10
stumblingtrout
Inspector Gadget
HighlandPete
Pass - it was a 2011 (11 plate) 530d M Sport with 19" wheels... I bought it used, and have since traded it in for the X3... Which I thought has the monitoring system as I saw someone mention that there is a coding thing to display the individual PSI?
      07-18-2013, 08:40 AM   #11
ponti33609
ponti33609's Avatar
Drives: 2014 x3 35i
2014 BMW/X3 35i  [0.00]
My MY14 displayed exactly which tire was low for me a few weeks back.
Regards,
Bob
