      07-15-2013, 05:10 AM   #1
RhoXS
Drives: 2002 Z3 3.0i + 2016 X3 28i
Memory Buttons
I took delivery of my 2011 CPO this weekend and now working through having a good working knowedge of the iDrive system. There are two things I cannot figure out.
1. - I want to save a particular destination (my home) into one of the memory buttons so when it is pushed the Nav system sets itself up to take me home. It was no problem programming the address book into a button but I have been unable to program a specific destination. Can this be done and if so how?
2. - Page 137 of the manual has a section called "Gas station recommendation". By pushing "1 'Navigation', 2 'Route information', and 3 'Recommended refuel', the remaining range is calculated and gas stations along the route are displayed.". I do not see "Route Information" after pressing "Navigation". What am I missing as the manual certainly cannot be wrong.
      07-15-2013, 07:56 AM   #2
Yeltzer
Yeltzer's Avatar
11
Drives: F25 xDrive 20d M Sport
2. - Page 137 of the manual has a section called "Gas station recommendation". By pushing "1 'Navigation', 2 'Route information', and 3 'Recommended refuel', the remaining range is calculated and gas stations along the route are displayed. I do not see "Route Information" after pressing "Navigation". What am I missing as the manual certainly cannot be wrong.
With regards to 1, you need to go into the nav itself as if you were about to start navigation. IIRC at the final step (before 'accept destination) you need to highlight the address you want and then press and hold the button you want to assign it to. Worked for me here the other side of the pond. Good luck!
F25 xDrive 20d M Sport in Alpine White, Pro Nav, Auto 'Box, 19" Wheels, Visibility Pack, Heated Seats, Reverse Cam w/ Top View, Sun Protection Glass, DAB radio
      07-15-2013, 08:58 AM   #3
The X Men
Drives: 2013 X3 35i
I think you need to program your address as home or to the contact list before you can save it to a button.
Left click twice to get into the Route Information menu or use voice command and just say Route Information.
      07-15-2013, 09:04 AM   #4
UKMS
UKMS's Avatar
United Arab Emirates
110
Drives: X7 40i
You can save any previous destination to a button (use your home address as a destination first) ....... go to your previous destinations list ..... highlight the one you want to save ... then press and hold the memory button you want to save it to for a few seconds ..... the system will be bleep ..... thats it saved
Unfortunately cant help you with the gas station thing as I dont seem to have that function on mine (a UK MY14)
MS
X7 40i - Mineral White - Merino Coffee - Lots of toys
      07-15-2013, 12:58 PM   #5
The X Men
Drives: 2013 X3 35i
MS
If I am right, you can save it that way, but when you hit the memory button, it will not start the destination for you.
      07-15-2013, 05:47 PM   #6
RhoXS
Thanks for all the good advice. It helped me figure out what to do.
All that is necessary, as stated above, is to go to the address book and just highlight the address to be put in memory. After the desired entry is highlighted just hold in the desired button for a few seconds. Whenever that button is then momentarily pushed the Nav system comes up with that destination already set in.
      07-16-2013, 02:30 AM   #7
UKMS
UKMS's Avatar
110
Drives: X7 40i
It does start the navigation on mine ...... this is the only way I have I have ever stored destinations to memory because I never store anything to the address book in the car.
MS
      07-16-2013, 03:00 PM   #8
The X Men
Drives: 2013 X3 35i
MS
I learn something new everyday
      07-16-2013, 06:09 PM   #9
Anfänger
perennial neophyte
Drives: SUV
In an earlier thread on this forum someone pointed out that if you set a memory key for your home address, it will provide a simple path to your home if someone steals the car. Of course there are many ways to find your home address, but you might at least consider naming the destination something other than "home", and/or saving a location that is near your home, but far enough away to not trigger your garage door opener.
      07-16-2013, 08:42 PM   #10
The X Men
Drives: 2013 X3 35i
You would think your car registration inside the car would give your address away.
      07-16-2013, 11:51 PM   #11
Anfänger
perennial neophyte
Drives: SUV
True, but you may have choices there, too. e.g., in NYS you can list a PO Box address on the registration document. You do have to list your residential address elsewhere on the application form, but that isn't printed on the registration or title documents.
