      09-15-2015, 12:10 AM   #1
asloudasitgets
Drives: m3
2006 BMW X3 3.0i Purchase
Hey Guys,
I looking at purchasing a 2006 BMW X3 from a friend of mine. The car has about 80,000 miles on it and from what my friend is telling me the only thing he remembers changing is the steering wheel sensor? and the transfer case replaced.
From what I know no maintenance has been done on the car and I expect I need a major service performed on it. I looked at tunermotorsports.com to get a rough cost of parts that I need to perform a major service and it costs about $1,200.00. So I am thinking with labor it will cost about $2,500-$3,000.00
The maintenance is very comprehensive, so I don't know if everything is necessary. Any input and thought would be appreciated.
spark plug replacement
ignition coil and coil boot inspection and replacement
fill and bleed cooling system
transmission fluid change
front and rear differential fluid change
transfer case fluid change
fuel filter replacement
engine and A/C serpentine belt replacement
replace belt roller pulleys and belt tensioners
engine oil change with filter
engine air filter replacement
replace brake rotors
replace brake pads
brake fluid flush/bleeding
Also is there any known issues with the 2006 X3? I just want to know what im getting into before purchase.
Thanks for in advance.
      10-15-2015, 04:48 PM   #2
humbertob
humbertob's Avatar
Drives: '16 BMW M235i
Thumbs up DIY
90% of what your X3 needs you can DIY for sure and save a ton of money ! I currently own a 2009 X3 and have done almost the complete list of mantainance with out any trouble for less than $1000
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i
'19 G01 X3 | Wife's
'15 F30 335i M-Sport | Son's
'10 Porsche Boxster
