      01-16-2024, 03:51 PM   #1
David916
Drives: BMW X3
Removed fuse # 121 and auxiliary fan STILL turns on.
Is there another fuse that i can remove to stop the radiator fan from turning on?
I just installed ISTA and INPA and would like to diagnose my car, but when I put the car in Accessory mode, the stupid fan turns on and drains the car battery, then I get a charge battery notification and the car turns off.
I have a 2011 X3 35i. Any advice would be appreciated.
      01-21-2024, 11:58 AM   #2
SigmundCremin
Originally Posted by David916 View Post
Is there another fuse that i can remove to stop the radiator fan from turning on?suika game
Removing the fan relay is only a temporary solution, as it might cause your engine to overheat or damage your air conditioning system if you drive your car without it. You should replace the fan relay as soon as possible with a new one that matches the specifications of your car.
