      09-26-2018, 10:30 AM   #1
chrispitude
Drives: E91 325xiT 6MT, F31 328xdT
17" winter wheel options for F25 X3
Well, it's time to put together a winter wheel/tire setup for my wife's new-to-us 2016 X3 28d. My preference is a 17" wheel/tire setup, for (1) ride comfort, (2) tire availability, and (3) cost.
But I know 17" wheels are a tight fit. Others have run the 17x7.5 style 130 wheels from the E53 X5 with success:
However, the 17x75 style 57 wheels from the E53 X5 have the same offset and are (1) easier to find, (2) cheaper to buy, and (3) easier to clean:
Has anyone tested the style 57 wheels on the F25? It probably depends on whether the barrels are shaped the same between the two.
Thanks!
      09-26-2018, 10:33 AM   #2
________
________
4159
Drives: ________
Wouldn't a rim that has the same specs as the stock X3 17" rims work?
Or just find some used X3 rims?
If I'm not mistaken offset is 32 for the 17" and the barrel sizes won't change much, and the brakes are very small on this car, I bet they wouldn't have clearance issues.
      09-26-2018, 11:28 AM   #3
chrispitude
Yes, but those style 57 wheels are a dime a dozen. An auto salvage yard about 45 minutes from me has *three* sets of four for sale right now. The X3 wheels are much harder to find.
________4158.50
      09-26-2018, 01:51 PM   #4
oVeRdOsE.
oVeRdOsE.'s Avatar
2712
Drives: F25 E91 Audi Avnt E90 Cayenne
17'' could be a nice choice for lower cost
just go a quote for 4x hakka 9 , 19'' : 1700$ cad. ouch
      09-27-2018, 11:46 AM   #5
chrispitude
Ebay has a 15% off code (not seller specific), good for today only. I just picked up a set of Hakkapeliitta R2 SUV tires, 225/60R17 RFT, for $395 shipped.
________4158.50
      10-08-2018, 07:49 AM   #6
Ol' Fart
Ol' Fart's Avatar
10
Drives: 2016 X3, 28d, Mineral White
For my winter setup I'm running 17" wheels off a 2008 335 XI, not sure what the model number is, but they look identical to my stock wheels except the spokes don't have the twist in them. The offset is close to the stock wheels. They should be readily available in the recycling yards.
Doug
2019 BMW 430 XI Grand Coupe, White, Black leather interior
2016 BMW X3, 28d, Mineral White metalic, Oyster Nevada leather interior.
Scout1086.00
      11-18-2018, 08:46 AM   #7
chrispitude
Went with E53 X3 style 130, got a pristine set of 2006 take-offs from a forum member for $250. They actually look quite natural on the F25 X3!
The RFT Hakka R2s have a very aggressive tread pattern, and the tread blocks feel noticeably more pliable than the tread blocks on the RFT Pirelli Winter 210 Serie 2 on my F31 328d, which is a very good thing.
The 17" wheels are indeed a tight fit (they clear the calipers by about 2mm) but they fit and drive great!
The factory F25 TPMS sensors did not fit the style 130 wheels as-is. However, Garrett (garrett@shoptpms dot com) got me an alternate set of sensors with increased angular range, and they installed perfectly on the wheels and were recognized by the vehicle.
Bring it on, winter!
nonot15.00
Scout1086.00
      01-27-2019, 12:13 AM   #8
RL325xi
Drives: 2006 e91
May I ask what tire size are you running ?
      01-27-2019, 09:10 AM   #9
richardodn
Drives: '12 X3 35iX/'20 440ix cabrio
Not sure what the poster is running, but for a 17x7.5 wheel the ideal sizes are 225/60/17 and 245/60/17. Make sure the load index is at least 98. Personally I'd run the 245 unless most of my time was spent driving in snow and ice. Then I'd go with the narrower 225.
If the poster is running the R2, it's likely the 235/55/17 which is close enough to the factory sizing.
