11-26-2016, 01:50 PM | #1 |
Rep 91
17 inch tire pressure?
Changed down to 17 inch rims for winter tires from the MSport 19 inch package on my 2014 X3 Msport 28I. Door jam lists only 18" inch wheel size for inflation pressures of 32/35. What are people running 17" run flat pressures at? Tire size is 225/60/17. Tire shop went 35lbs all four corners.
11-26-2016, 05:00 PM | #2 |
Rep 287
I also use 17" winter tires and rims. I set them to 34/37 respectively since the cold temperature will lower the air pressure when stationary.
11-27-2016, 08:15 PM | #4 |
Rep 70
Drives: 2011 BMW X3 35i
I run 34 Front - 36 Rear in winter
11-28-2016, 10:32 AM | #6 |
Rep 182
Drives: '18 G01 X3 M40i
I tend to keep the front/rear pressure ratio the same regardless. i.e.. door says 32-38 so ill always make sure the rear has +6 psi over the front thats what feels best to me.
11-28-2016, 10:34 AM | #7 |
Rep 182
I tend to keep the front/rear pressure ratio the same regardless. i.e.. door says 32-38 so ill always make sure the rear has +6 psi over the front thats what feels best to me. Then again I haven't changed from the OE 19" tire size
