      05-10-2016, 03:16 AM   #1
msb100
Drives: X3 30D F25
Guide to replace front shocks?
Has anyone replaced the front shocks (with EDC) on their X3 F25?
Is there a guide somewhere?
Thanks
      05-10-2016, 11:17 AM   #2
Pinewood
Pinewood's Avatar
Drives: BMW X3 30d M sport LCI
Wouldn't you have to replace all 4 and code it?
      05-10-2016, 12:48 PM   #3
Tjalle
Drives: X4 35i
BMW has some funny rules - to earn money? - but it should be possibel to exchange front shocks only.
I don`t see why EDC should be coded.
When I installed H&R springs - all around, I got an offer from BMW dealer of 6 hours and £600. My car has EDC.
Local shop- takes on "all" cars- run by two 60+ gentlemen did it for 4 hours and £300, which indicates fairly easy job and no coding. They commented on it being easy because of no corrosion.
      05-10-2016, 01:46 PM   #4
Pinewood
Pinewood's Avatar
Sorry i'm getting EDC confused with VDC.
So what is EDC
      05-11-2016, 12:42 AM   #5
Tjalle
Drives: X4 35i
Electronic Damper Control. I.e. 12V creates a magnetic field, which makes the fluid "stiffer".
Invented by GM R&D about 20 years ago and developed/ marketed by DELCO/Delphi
      05-11-2016, 12:55 AM   #6
msb100
Drives: X3 30D F25
Hi,
I already have EDC (Electronic Damper Control) in my Car.
One of the front shocks is leaking and needs to be replaced.
I think I would need to change only this one and don't think any coding would be required.
Just looking for 'how to' guide on replacing the strut. Thanks.
      05-11-2016, 08:36 AM   #7
Polo08816
Drives: 2014 335i M Sport
Originally Posted by msb100 View Post
Hi,
I would search for the ISTA+ application. It has the workshop manuals in it for what you need.
      05-12-2016, 12:41 AM   #8
msb100
Drives: X3 30D F25
Hi,
I did some searching on google and hat ISTA looks like a diagnostics software. Does that also include repair/service manuals?
Any link to download?
      05-12-2016, 01:42 PM   #9
Polo08816
Hi,
Yes, if you have the SQLiteDBs it will contain pretty much ALL the service manuals up to a certain date for all vehicles. That's why it's anywhere from 50-60gb. The Bentley Service Manuals take directly from it.
You will probably want all the necessary preliminary tasks, but I've included these to give you a preview.
www.cartechnology.co.uk
      05-13-2016, 12:24 AM   #10
msb100
Drives: X3 30D F25
Wow.. thank you so much.
Do I need to download the entire 60gb package or just the SQLiteDBs would be sufficient? That's about 10GB.
Thanks.
      05-13-2016, 09:53 AM   #11
Polo08816
Thanks.
For diagnostics, you just need the ISTA+ Rheingold and the SQLiteDBs.
The 60gb package includes the PSdzData Full which is needed to firmware flash and code via ISTA+ your car provided you have an BMW ICOM A2 clone which is about $300.
If you have a ~$20 ENET cable, you will be able to do all of the diagnostics. If you want to flash, you'll need to do it via E-Sys.
I wish the X3 forum was as active as the F3x forums.
      05-14-2016, 12:57 AM   #12
msb100
Drives: X3 30D F25
Great... Thanks.
