      06-17-2013, 06:54 PM   #1
rbtamms
rbtamms's Avatar
Philippines
63
Drives: 2011 E90 and 2013 F25
2011 328i  [0.00]
F25 Running Board
Has anyone tried this running bumper from Australia? I tried searching one on F25 but couldn't find one.
http://marsperformance.com.au/BMW-OE...r-F25-10-13-X3
      06-17-2013, 09:03 PM   #2
hobbesvr6
Drives: 3.2TL
rbtamms - I found this on ebay. I have been searching for someone to see if they have install it or not.
http://www.ebay.com/itm/11-13-BMW-F2...-/151039093966
      06-17-2013, 10:48 PM   #3
Teemo Panda
*Bimmerpost Plasti Dip Guru*
Teemo Panda's Avatar
Drives: E53, E46-M3, E70, F25-X3
2013 BMW X3  [5.66]
I seen a 2011 or 2012 F25 28i With a running board attached to it when i was at costco, not sure if it is the same as this one thou~
      06-18-2013, 01:08 AM   #4
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
Good find, but we're not sure if this is the actual running board because it mentioned as nerf. Nerf is actually just hanging below the door sill with a gap. I was looking for something entirely attached like the x5.
I will try to contact the seller if the first picture is the actual board.
      06-18-2013, 01:11 AM   #5
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
Does it look the same as the X5? You should have taken a picture, so we can see.
      06-18-2013, 10:04 AM   #6
jsl1419
Drives: 2012 BMW X3 35i M sport
Just want to show how it look like with M sport
M sport side skirt should be removed to install it.
You can find it from ebay.
      06-18-2013, 11:00 AM   #7
ponti33609
ponti33609's Avatar
Drives: 2014 x3 35i
2014 BMW/X3 35i  [0.00]
Thx for the pictures. Looks nicely done.
Question or Poll to others. Where our X3's are a bit smaller/sportier IMO than an X5 ......do you like these? I am not sure I do yet I do like them on the X5.
Regards,
Bob
      06-18-2013, 12:01 PM   #8
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
Very nice, I'm almost ready to pull the trigger to buy this running board. So you got this from ebay? Did you just install it yourself?
      06-18-2013, 02:20 PM   #9
guyver626
Drives: 2014 35i m-sport carbon black
How is the quality of the side steps? Can it actually hold your weight? Since the side skirt has to be removed does it look alittle off or "funny" without the side skirt? Can you take a few pictures showing the whole car.
      06-19-2013, 02:57 PM   #10
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
I just pulled the trigger to buy one on ebay:
      06-20-2013, 08:30 AM   #11
The X Men
Drives: 2013 X3 35i
Those looks much better in the X5.
      06-20-2013, 11:18 AM   #12
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
Because the X5 door sills are further in, to make running board flush with the fenders. That's why it looks good on X5. BMW added this running boards on E83 as accessories, I wonder why they did not do it on F25?
That's why I wanted to do this project, I will add a fender arch extension to make the fenders align with the running board. Then I will eventually buy a wider wheels & tires that will flush with the fenders & running board.
      06-20-2013, 12:12 PM   #13
The X Men
Drives: 2013 X3 35i
Thats a lot of work for a running board that no one is going to use and doesnt really add much to the look of the SUV To each his own I guess.
      06-23-2013, 08:17 PM   #14
hobbesvr6
Drives: 3.2TL
Looking forward for you to install it and take some picture after you finish
      06-24-2013, 12:48 PM   #15
steelerfan
steelerfan's Avatar
163
Drives: 2017 X5 Silver
Subscribed... also wanting to see what these look like installed
      06-24-2013, 09:28 PM   #16
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
Got the package when I got home today...
      06-24-2013, 09:41 PM   #17
steelerfan
steelerfan's Avatar
163
B/c it would give him an overall more agressive stance when looking at the front of the vehicle to the back.. similar to the X5... I can't wait to see this b/c X5's look a lot better IMO with a running board...
Can't for the pics & the fitment details... DIY please...
      06-30-2013, 03:54 AM   #18
hobbesvr6
Drives: 3.2TL
Looking forward to see you install the running board. I might order one myself.
      06-30-2013, 07:39 AM   #19
guyver626
Please let us know the quality of the parts!! Also can you do a DIY?? We are all very interested
      06-30-2013, 09:49 AM   #20
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
I was working on this yesterday afternoon but got stuck with the reinforcing piece, because I don't have the tool to drive in the blind rivets to hold that piece. Did a test fit...the quality & fitment is actually good. It's just like & play, except for the reinforcing piece that needs to be secured first. But don't worry how to position it because there are two holes with rubber plugs in the frame that will serve as a guide. I just run out of time last night because my wife has to go to work...she will freak out if she finds out that something is missing in her car.
I took some pics & will upload it as soon as I'm done. I will try to explain the best that I can about the details on how I installed it.
      07-01-2013, 01:15 PM   #21
rbtamms
rbtamms's Avatar
Philippines
63
2011 328i  [0.00]
Here are some pics of my installation:
After removing the OEM lower plastic panel
The reinforcement piece
Remove two rubber plugs & the holes are the guides where the reinforcement should align
I put some duct tapes to hold the reinforcement while I'm drilling holes for the rivets. I used 5/32" drill bits & once you hit something, stop right there & don't drill beyond that.
I put lots of rivets to make it strong & safe to setp on. I used 5/32" diam. x 1/2" long rivets. The rivets will not sink all the way through because there's a brace behind the body shell. Don't worry, as you crimp the rivets, it will get shorter & eventually the rivets will flush in before the excess pin snaps off.
If you haven't use a rivet tool before, please watch this
https://www.youtube.com/watch?v=7qv9xWTunwA
After installation
I only did the right side because I run out of time. When I'm done, I will take some photos outside so you guys can see the overall look of the car with the running boards.
      07-01-2013, 02:43 PM   #22
LalV eVo
LalV eVo's Avatar
Drives: 14' CB F25 35i M-Sport
looks good!
2014 Carbon Black X3 35i M-Sport
2008 SGM 328xi Coupe - retired
2000 SG 323cic - retired
