      08-15-2012, 03:38 PM   #1
cadman50
Drives: 2012 X3 35i, 2021 X3 M40i
Temperature control thumbwheel on dash
I'm still puzzled why that's there. If you have automatic climate control, then you set the temperature at a desired point. If you want the temperature to go higher, you just turn up the dial. Same for lower...turn down the dial setting from, say 70 degrees to 68. But by turning the thumbwheel up or down aren't you accomplishing the same thing?
      08-15-2012, 03:59 PM   #2
jt2
Annoyance
Drives: Yes
Do you mean the blue/red air mixture thumbwheel on the center main vent?
      08-15-2012, 04:35 PM   #3
cadman50
yes. If you have the auto climate control temp set 70 degrees, then by rotating the thumbwheel towards the red the temperature of the air coming out of the vents becomes more warm and vica-versa. So if yo want warmer air out of the vents, why not just turn the auto climate temp control setting up a few degrees?
      08-15-2012, 04:54 PM   #4
HighlandPete
Drives: BMW F11 535i Touring
It is simply a fine tuning of face vent air temperature.
You can run the cabin temperature on the auto setting and have the option to blend to face as you desire.
Been a feature of BMW models for years, and from my perspective one of the best features, which makes Climate Control a decent bit of kit, and much easier to live with.
For me, as an example, in winter time can have a warm cabin, but a bit of fresh air to the face "blended perfectly" to whatever temperature I want.
HighlandPete
      08-17-2012, 11:54 PM   #5
96_Impreza
96_Impreza's Avatar
12
Drives: 96 Impreza,07 Vette,11 X3 35i
Thanks, HighlandPete. I've wondered also but didn't find anything in the manual.
      08-18-2012, 04:27 AM   #6
NordicBMW
NordicBMW's Avatar
Norway
Drives: 2012 X3 / 2013 X1
My X3 is my first car with this feature. At first I didn't see the point but now I've started to really appreciate it. The same goes for the kids in the backseat.
      08-18-2012, 04:48 AM   #7
midlifecrisis
midlifecrisis's Avatar
807
Drives: 2017 X5 35d, 2019 230i X
I love this feature. Whenever I get into a car without it I can never seem to fine-tune the climate control to my taste. I find it most useful on dreary summer days when you have to run the compressor to keep fog off the windows. You can adjust the air coming out of the vents so they don't freeze you out of your seat.
This is just another little detail that every premium car should have.
2017 X5 35d (Performance Center delivery March 2017)
2019 230i X-drive
2022 M3 base
2000 328i sedan (UUC suspension - still the favorite), 2006 M3 slick top - Alpine White/Cinnamon
SOLD! 2008 E90 M3 SOLD! 1991 325iX (both great), 2019 Miata RF - various others not as memorable but gone.
      08-18-2012, 07:42 AM   #8
lbjgh
lbjgh's Avatar
Drives: 2013 AW X3 M-Sport
I too was skeptical about the benefits of this fine tuning dial but I am a fan of it now.
The seats are not ventilated so i keep the cabin temperature a little cooler than previous cars and adjust the dash outlet dial to the middle position. If it is humid or very hot outside I just dial in a little more cool air. Cool.
Btw even Hyundai has ventilated seats... What gives with bmw?
      08-18-2012, 08:54 AM   #9
midwest 340xi 6sp
midwest 340xi 6sp's Avatar
Drives: 2018 340xi
HighlandPete
This is exactly right....I can have nice warm air on my toes in the winter and cooler air to my face...It's a simple and effective feature..
I remember when I bought an E60 5'er and they didn't have it - I couldn't believe they did away with it...
Then I realized (in typical bmw fashion) they put it in the idrive and made it electronic On my E92 M3 it's back to a simple wheel, and glad to see it that way on the F25 too
Previous Rides: 535xi, M235xi, X3, E92 M3, E70 X5 35d, X6 50i, X6 35i, E60 550i, E46 M3 Cabriolet, E39 540i, E36 328i
      08-18-2012, 10:04 AM   #10
rmeir
Drives: x3
doesnt that just direct air flow?
      08-18-2012, 10:13 AM   #11
lbjgh
lbjgh's Avatar
Nop. There are dials on either side of the vents to control flow. The middle dial controls temp.
      08-18-2012, 11:45 AM   #12
cadman50
HighlandPete
Nice feature.....I guess. I've yet to really use it other than setting it for max red or blue depending on the season. Actually I turn off the top vents in the winter preferring to have heat coming up from the bottom and rising thruout the cabin and using the heated steering wheel which is really nice. But in the summer I like to have those vents open especially on the hot days when I'm using AC. That's when I could see turning it towards warmer a little so I don't get frozen in the face. Thanks.
      08-19-2012, 11:39 AM   #13
HighlandPete
No, this is definitely a temperature control. Description as for the E9x model IHKA system.
Front Stratification Adjustment Thumbwheel
The thumbwheel signal is wired directly to the IHKA control unit as an analog/varying voltage signal. The IHKA panel sends the specific position signal to the front mixing flap motor via the LIN bus.
HighlandPete
