05-10-2013, 08:19 AM | #1 |
Rep 147
Stutter during acceleration
I have a '13 X3 with 7k on it, and 4 times I've experienced the car stutter or buck under acceleration. I only use 91 or 93 octane, so I ruled out bad gas and I noticed its always at low RPM's under 2k. The car will buck, like it is not getting enough fuel, or the air/fuel ratio is dorked up.
Searching showed me some folks experienced this in previous versions and it was typically an O2 sensor or bad crank shaft sensor. I'll mention this when I bring it in for the first service, and just wanted to know if anyone else has experience this. Last edited by BigJake; 05-10-2013 at 09:26 AM.. |
05-15-2013, 10:26 AM | #3 |
Rep 64
I have a '13 X3 28i and mine totally does this.
It only happens in warmer weather. I noticed it last summer but it was absent all winter. Now that the weather is warming up, it has started doing it again. I've checked the engine codes and no errors have been thrown. I did mention it to the service manager when I was in for an oil change. He insisted (rather rudely) it was the gas. I only use Shell premium. I now keep ALL my gas receipts in case it becomes an issue in the future. I don't go to that dealer anymore though (Gebhardt in Boulder, CO). The tough thing about the issue is that it is hard to reproduce. It doesn't always do it. So the dealership will just give you the gas song and dance if they can't reproduce it. Let me know if you find anything out. |
05-15-2013, 01:25 PM | #4 |
Rep 144
Drives: 2012 F25 N52T
There is a Service Bulletin issued specific to this issue, but for '12 models.
Service Bulletin No.: SIB-12-09-12 Component(s): ELECTRICAL SYSTEM , ENGINE NHTSA ID Number: 10049299 All Products Associated with this Service Bulletin close Vehicle Make Model Model Year(s) BMW 5-SERIES GRAN TURISMO 2012 BMW BMW 9999 BMW M3 9999 BMW M5 9999 BMW X3 2012 BMW X5 2012 BMW X6 2012 Manufacturer: BMW of North America, LLC SUMMARY: BMW: WITHOUT RELEVANT FAULTS STORED IN DME MEMORY, WHEN AT LOW SPEED MANEUVERING AND IDLING, OR STEERING TURNED TO FULL LOCK POSITION, OR DRIVING OFF THROTTLE (COASTING) AND BRAKING AT 10MPH, VEHICLE WOULD IDLE SPEED MAY FLUCTUATE UP AND DOWN OR CUT OFF. MODELS 2012 E70, 71, 82, 88, 90, 92, 93, F07, 10, 12, 13, 25. *PE UPDATED 05/13/2013 *JS |
05-15-2013, 02:44 PM | #5 |
Rep 64
This doesn't sound quite like the issue the OP or I are experiencing. At least in my car, it happens under acceleration, sometimes hard acceleration, but around 2K-2.5K RPMs.
I would love it if there were a SB for this to show my dealer though! |
05-15-2013, 05:26 PM | #6 | |
Rep 1,876
05-15-2013, 07:35 PM | #7 | |
Rep 5
05-29-2013, 11:19 PM | #8 | |
Rep 192
08-29-2018, 06:43 AM | #10 |
Rep 3
Hi all. I am experiencing the same issue on my 2015 F25 2.0 D. 27k miles. It pulses, jerky, on acceleration. I would be really grateful for any pointers on if anyone else has experienced it and how it was resolved. Thanks in advance for your help.
08-29-2018, 08:09 AM | #12 |
General of the Space Forces
171
Rep 721
I had the same issue with my 2011 X3 35i, hesitation like a faulty shift when accelerating under 2k rpm, turned out to be a bad spark plug.
I would get your plugs and coils checked, or maybe just replace depending on when they were done last. |
08-29-2018, 08:40 AM | #13 |
Rep 2,527
Any chance it could be misfire? ie., coil packs and spark plugs
Same as what najnad ^ is saying. You would also get CEL and a drivetrain fault warning on screen if you push the car hard while it's misfiring. |
