      08-25-2018, 10:14 AM   #1
iceman3
Drives: 2011 x3 35i
2016 BMW X3 35i  [0.00]
staggered wheels
I own a 2016 x3 with m sport package that has staggered 20" wheels. My rears are getting pretty bald so I was going to replace the tires or use the after markets from my 2011 x3 255/40/20 all around. After researching sizes I found that my oem set are different diameters. The rear pirelli's 275/35/20 are 2/10 shorter than the fronts 245/40/20. I was always under the impression that they had to be the same. Does anyone know if the M sport package has a different gear setup to accommodate this or is there a tolerable difference in all of them, and if so how much difference can I have? I called two dealers and of course you aren't allowed to talk to anyone that knows anything, but got two different answers as to whether I can use my same size tires from my 2011.
      09-05-2018, 08:49 AM   #2
________
________
4159
Drives: ________
You can use any size you want, as long as the diameter differences are within 1% between axles.
That makes a square setup obviously acceptable, and the OEM staggered sizes too.
Going over 1% is said to overload the transfer case.
      09-05-2018, 08:57 AM   #3
Merlin82
Drives: 2011 BMW X3 Xdrive35i
Ya I think its more about the percentage difference in the revolutions per mile of the tires. When I bought new tires, one of the reasons I bought the continentals is because they were the closest front and back for revs per mile. Plus they were also a little lighter than some of the other options. For some reason I thought that it was up to 3% difference but it may be 1% like Onerdriver said.
      09-05-2018, 09:31 AM   #4
________
________
4159
Drives: ________
3% is the industry recommended maximum diameter difference, so as to not affect the car original dynamics, mostly braking capacity. And it also alters the speedometer reading.
1% is said to be the threshold for XDrive due to the transfer case (it works harder when tires are of different diameter).
      09-09-2018, 08:39 PM   #5
iceman3
Drives: 2011 x3 35i
Staggered wheels
Thanks guys for the help. Can get my wheels on.
      09-10-2018, 11:53 AM   #6
x3sm
x3sm's Avatar
282
Drives: M3 E93 Porsche
Does anyone know if it makes sense to put a square set up on a X3? Like 275/40 all around with 19x9.5 wheels?
      09-10-2018, 12:11 PM   #7
________
________
4159
Drives: ________
Why wouldn't a square setup makes sense?
It's how it comes from factory.
In regards to the size you mentioned, the only possible issue would be rubbing up front.
      09-10-2018, 12:15 PM   #8
x3sm
x3sm's Avatar
282
You are right... Do you know what the widest tire that can fit in the front? I guess it depends on the wheel width and offset, but any known members with wider than 255 up front?
      09-10-2018, 04:11 PM   #9
Merlin82
I tried a set of X5 wheels on mine which has the 275's in the front and they just barely rubbed the struts. They would likely fit with a small spacer or maybe different offset. Other than rubbing the strut they didnt seem to contact anywhere else.
