04-20-2015, 05:26 PM | #1 |
Rep 91
LCI auto start/stop
I have now had my new car for a week and whilst I am quite thrilled with its smoothness, less outside noise, and some of the new features it has, I am very disappointed that the auto start/stop function has changed from my previous 2013 model year car. There now appears to be no way to prevent the engine from switching off when coming to a stop at traffic lights, unless the auto stop function has already been deactivated earlier. Clearly, if you are going to be stationary for only a few seconds, you don’t want the engine shutting down.
Previously it was quite easy to keep the engine running, (most of the time) if the pressure on the brake pedal was released slightly after coming to a stop; now one has no choice, and the engine switches off as soon as the car has stopped. So, just wanted to know if that is the norm these days, or if perhaps my setting is over sensitive and can be corrected, as it cuts out immediately the car comes to a halt. Another disappointment is the mandatory daytime running lights, where it is no longer possible to switch them off.
Current: X3 30d Auto MY2016
Previous: X3 20d Auto MY2013 |
04-21-2015, 02:25 AM | #3 | |
Rep 746
Drives: X3 20d Xline Melbourne Red
DRL's are a legal requirement in EU that's why you can't disable unlike older cars
Gone: E90 crimson red/black
Gone :X1 23d Msport manual, Space/Beige Pro Nav, Adaptive zenons, privacy glass, 18's, ext storage, Current: X3 20d Xline auto, Melbourne/Beige, Sport seats, Viz pack, heated steering wheel, Folding mirrors, privacy glass, luggage net, pro nav Current: E85 Z4 3.0si roadster titanium/Syrah individual Current: F31 320d touring black/black work hack |
04-21-2015, 02:55 AM | #4 |
Rep 2,073
I find the start/stop is much improved over my 2011 X3. My LCI engages start/stop less often whereas my 2011 did it infuriatingly often. I find my LCI moves away smoothly when I press the accelerator, with my 2011 I had to tweek the steering wheel instead of pressing the accelerator to start the engine - if I didn't us the the steering wheel (or Sport) the car lurched forward uncomfortably.
Er yes....DRLs are required.
04-21-2015, 03:48 AM | #5 |
Rep 518
Odd, I haven't noticed a difference - I know the little tricks you're referring to with braking (classic use case being a long run up to a red traffic light when you know it's about to change and you don't want start/stop to kick in for the 1 or 2 seconds that you're stationary). My personal technique has been to apply the brake gently and I'm sure this still works on my LCI (2.0d SE with auto box).
Unrelated but the other thing I love on the LCI is that if you slow gently then the parking sensors automatically switch on - no need to wait to go into reverse or press the button.
G26 420d Gran Coupe MSport Black on black, MSport Pro Pack, Comfort Plus Pack, Harman Kardon audio
04-21-2015, 04:15 AM | #6 | |
Rep 91
I completely agree that the engine restart is so much quicker and smoother than before, but I would prefer to have control of it as I had in the 2013 model.
Previous: X3 20d Auto MY2013 Last edited by Rich4; 04-21-2015 at 05:10 AM.. |
04-21-2015, 04:22 AM | #7 | |
Rep 2,073
04-21-2015, 04:26 AM | #8 | |
Rep 91
Yes, the cameras are far better now, and so are other features - I just love it, except for a couple of issues, including my start/stop
04-21-2015, 04:37 AM | #9 | |
Rep 91
Perhaps other LCI owners would care to comment?
04-21-2015, 05:00 AM | #10 |
Rep 2,073
I believe also X3s get different battery sizes depending on options installed. Maybe they've de-rated the battery for the LCI. This or some other LCI changes could well be behind the less frequent start/stop I experience. The software management of these cars is a minefield.
04-21-2015, 01:12 PM | #12 |
Rep 91
Thanks, will try that though it needs precise timing as my engine switches off as it stops - not even one second later. It might worry drivers either side or the cop behind me!
04-22-2015, 04:58 AM | #14 |
Idiot-in-chief
31
Rep 218
IMO, Auto Stop/Start is one of the worst 'features' ever to be added to a car, it's been developed solely to eek out a few extra percentage points in the CO2 emissions tables without worrying too much about the extra strain it places on other components in the longer term.
The manufacturers claim that they've beefed up the batteries and starter motor to cope with this additional load but it appears that they've only beefed them up enough to avoid lots of in-warranty failures. Sticking with BMW, the initial models of auto stop/start cars are now around 7 years old and, if you do a bit of googling, you'll find plenty of examples of what would normally be considered premature battery and starter motor failure I've coded our F25 so that auto start/stop is normally disabled and we have to actively switch it on if we wish to use it.
X3 F25 LCI 30d M Sport
Alpina Roadster S |
04-22-2015, 06:49 AM | #15 |
Rep 560
I sometimes press the deactivate button as soon as I start the engine. If that feature is no longer available, I would flip the gear stick to sport mode when you stop and this prevents the engine from turning off. I have been doing this recently and it is quite useful as there are occasions when I let the engine switch off if the traffic looks to be stationary for a long time.
04-22-2015, 07:19 AM | #16 |
Rep 2,073
I quite like start/stop. Even with the 6 pot diesels there's a slight vibration when the car is idling. It's so much more serene with the engine off. It's easy to defeat if you don't like it.
04-24-2015, 12:32 PM | #18 | |
Rep 518
04-24-2015, 12:46 PM | #19 |
Rep 11,843
Drives: MY24 G01 AW Msport
just press the button to left, it deactivates the feature
04-24-2015, 01:23 PM | #21 | |
Rep 1,108
I don't mind it, but sometimes when it's stop and go frequently, it gets annoying. However, the logic for it seems to be pretty good. It seems to know not to activate if I only move up a little bit. Like others have suggested, the only guaranteed way seems to be moving to the Sport mode to disable it while the car is running. |
04-24-2015, 01:37 PM | #22 |
Rep 518
OP knows that Think he's happy to have start/stop on but just wants the ability to over-ride when he knows it's a very short pause. On the original F25 this was possible with gentle braking but now it seems start/stop always kicks in (once the engine is warmed up etc)
There are plenty of ways to re-start - twitch the steering wheel, tap the accelerator, move the gear shift to sport etc but I think he's trying to avoid the stop in the first place but not all the time. Correct Rich4 ?
