09-23-2016, 10:08 AM | #1 |
Rep 61
Water drains from door when opened.
In case anyone has experienced the same issue - When I leave my X3 parked for a while in wet weather, I find on opening the driver's door a quantity of water drains out onto the road. This has apparently been held within the door until this point. I presume it is entering the door down the outside of the window past the outer rubber horizontal strip, though the strip looks OK visually. Has anyone experienced this, is it really a problem, what might be the cause.
thanks, |
09-23-2016, 02:36 PM | #2 |
Air Vice Marshall
256
Rep 1,639
If the water is draining out of the holes (they are drain holes) then this is normal and to be expected. It happens on all cars.
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium |
09-25-2016, 12:38 PM | #3 |
Nuclear Chief of the Watch
120
Rep 637
yes it is normal and does sometime seem a lot of water - but its fine.
BMW X3 (F25) xDrive20d SE 2017. . . . Oyster Leather . . 8 Speed Servotronic. .RFTs. . Electric Seats Canon 70D 500mm, 85mm, 40mm, 24mm Sony QX10 & GoPro Hero 3 |
11-20-2016, 06:16 AM | #4 |
Rep 594
Having owned the car for the last 3yrs, I came across this today. I opened the drivers door and what seemed like a lot of water fell out. When I looked at the bottom of the door you could see the water dripping off the main plastic section of the door, near to the puddle light, so it must have built up quite a bit.
If this is what other people have seen, then no problem, but it did seem like a lot of water! It made quite a splashing sound, which as I say is unusual and never seen before. |
11-20-2016, 06:56 AM | #5 | |
Air Vice Marshall
256
Rep 1,639
2012 BMW 320d Sport (F31). 2013 BMW X3 xDrive 30d M Sport (F25). 2020 BMW X1 xDrive 2.0i MSport (F48). 2022 MB EQB 300 4MATIC AMG Line Premium Last edited by Peter_R; 11-20-2016 at 07:02 AM.. |
11-20-2016, 07:24 AM | #6 | |
Rep 594
11-20-2016, 08:21 AM | #7 |
Rep 594
I was able to reproduce it by pouring water against the corner of the drivers side door window and saw some water come out of the very bottom of the door, as well as some between the plastic door panel, so there is definitely an issue some where.
The same process on the other doors show no sign of water coming from between the plastic door panel and the metal frame. |
11-22-2016, 06:55 AM | #9 |
Rep 594
