01-06-2024, 04:02 AM | #1 |
Rep 9
Alloy wheel conversion
Hey people,
After some advise. I recently purchased a 2012 X3 2.0 X-drive which has some questionable alloys as standard. The current tyre size is 225/60/17. I am thinking of buying some 18” rims but would like to know what tyre size I require to keen the same rolling distance??? Has anyone put larger alloys on and what was the ride quality difference? Thanks |
01-06-2024, 09:31 AM | #3 |
Rep 9
Thanks for the reply.
Do you know if my calculations are correct? From the research I have done, correct me if I am wrong. My tyres - 225/60/17 225mm wide 135mm tyre wall height (60% of width) 270mm (top and bottom) 432 alloy height Total = 702mm 245/50/18 245mm wide 122.5mm tyre wall height 245mm (top and bottom) 457mm alloy height Total = 702mm This would equal overall circumference. Therefore would be okay for Speedo issue and rolling feel. |
01-09-2024, 10:06 PM | #8 |
Rep 384
Drives: 16 X3 28d/18 540d xdrive
Yes, ride quality with the 18" wheel and tires will be negatively affected. My 28d xdrive arrived with 245/50-18 tires and my winter tire set is 225/60-17. The latter rides better and yields better gas mileage. Other than appearance, I don't see any advantage in going with the 18-inch wheels and tires.
DannyX30.00 |
01-12-2024, 08:08 AM | #10 |
Rep 9
