09-02-2017, 08:11 AM | #1 |
Rep 201
Help Diagnose Possible Battery Issue
Hello,
Thursday at work, I got back to the parking lot after lunch and went into the office. I had to go run a quick errand so about 30 min later I ran out to the car, hit the start button and all electricals came on but car didn't start. I got a buddy to give me a jump and it fired right up. I then drove it home so that I wouldn't be stranded. I got home threw my trickle charger on it and after a few hours the charger indicated 80% and then overnight it indicated fully charged. It starts up just fine now but I am a tad worried that it may die on me again (I will be keeping jumper cables in the car) Battery Voltage Last night after it being fully charged (using a volt meter on the battery) 12.4v Battery Voltage this morning on the Battery after sitting for 12 hours 12.1v I found the hidden menu and it showed my voltage without the car started at 12.2v and when i started the car it went down to 8.4v for a split second and then came back up to 14.0v I have heard if the battery goes below 9v on startup you have a bad battery. Is this the case? As I am getting 14.0v at idle it sounds as if my alternator is fine. There are no warning lights, I never got a low battery charge light, no flickering lights. Thoughts? 2011 X3 35, I am not sure if it is original battery, I have owned it for 3 years and it has not had a new battery in that time. |
09-02-2017, 12:00 PM | #2 |
Rep 201
Went to Autozone, tech there said the alternator passed, battery passed but the starter showed an error.
Got home, used my BT cable and did not see anything in regards to starter but saw a lot of under voltages Short Test Digital Engine Electronics Current Fault Codes CD9437: DSC, FlexRay: Communications fault 213A21: Vehicle voltage: Voltage too low Footwell module Current Fault Codes 800FB9: Outside mirror, undervoltage 800F3D: Output, fog lights, right, short-circuited 800F92: Welcome light, repeat interlock, active Central Gateway Module Current Fault Codes 801C15: Fault is stored 801C06: Fault is stored 801C20: ZGM: central fault memory full - no control-module fault Junction-box electronics Current Fault Codes C90C96: Electrochromic interior mirror: internal fault 802102: JBE: undervoltage Integrated chassis management Current Fault Codes 48279B: ICM: Undervoltage in vehicle. Function Center, Roof Current Fault Codes 801A4C: SINE: undervoltage detected in internal voltage supply High Beam Assist Current Fault Codes E0C414: FLA, K-CAN: communication fault Combox emergency call No Faults Found Car Information Computer Current Fault Codes E1C440: Fault is stored in memory but is not currently occuring Seat module, driver Current Fault Codes 8029D4: SMFA: Undervoltage detected Trailer module Current Fault Codes 802819: AHM: Terminal 30F_B: Voltage supply missing/disruptedFault is stored in memory but is not currently occuring 80281B: AHM: undervoltage (terminal 30F_B)Fault is stored in memory but is not currently occuring 802837: Tail light, deactivation due to undervoltageFault is stored in memory but is not currently occuring |
09-02-2017, 08:56 PM | #3 |
Rep 268
Sounds to me like you have the culprit in sight... bat
What is the name on the battery thats in it??? or p/n
2017 BMW X3 x28i SOLD
2015 Honda CRV-EXL AWD 2019 Honda CRV-Touring AWD 1965 Chevrolet Corvette 327 / 4spd Convt |
09-03-2017, 07:48 AM | #4 | |
Rep 201
Battery shows BMW 12V 90Ah 900A 160 RC 900CCA 158 558-10 US If this is a battery issue, why would Autozones tester say the battery was good and that I had a starter issue? Thank you!! |
09-03-2017, 05:09 PM | #5 |
Rep 679
If the battery is 4+ years old, consider it preventative maintenance. There will be a date code (birthday) stamped into the battery somewhere (month/yr) - All BMWs now are very sensitive to low batteries due to the electronics, and they toss multiple weird/random codes when it goes out.
The battery test assumes it can put on a XX% load and the vehicle will start, BMW electronics could look for a minimum XX+1 %... Go get http://www.mycarly.com/product/bmw-app/ and register the new battery. Or if you swing by Plano (North Dallas), I'll do it for you... |
09-08-2017, 08:48 PM | #6 |
Rep 268
Isn't there also a way to date the battery by the p/n or s/n
he posted? I'd have to say its not the original...... but miracles do happen !
01-12-2020, 08:30 PM | #7 |
Rep 965
Was this ever resolved? I just ran into the same issue, and I even charged the battery over night the other day on the CTEK (although did it directly to the trunk), doing it now from under the hood. I'm running a AutoCraft Platinum AGM Battery, Group Size H8, 900 CCA.
01-13-2020, 01:36 AM | #8 | |
Rep 2,912
01-13-2020, 05:06 AM | #9 |
Rep 350
Here's a convenient chart on battery voltages and charge levels. https://www.energymatters.com.au/com...age-discharge/
As Opie55 stated, 12.1V on a recently charged battery is way too low. Either the battery is dying or there is excessive draw on the battery when the car is off. For example if the car never goes to "sleep," you'll be discharging your battery much more quickly. |
